Thread Tools Search this Thread Display Modes
Old 05-01-2012, 12:39 PM   #1
29ModelA
29ModelA's Avatar
Default Do all generators require to be lubed?
I am assuming they didn't have sealed bearings. Mine is a replacement generator, and I am not sure where to lube it.
1929 Model A Barn find. California car, just a few more parts to find.
Interior, steering box (rebuild), and I am sure much more!
29ModelA is offline   Reply With Quote
Old 05-01-2012, 03:48 PM   #2
ctlikon0712
ctlikon0712's Avatar
Default Re: Do all generators require to be lubed?
Close to the center of the front and rear plate there are oil caps.... with flip top lids. Pop them open and oil away. Yours is a 30-31 and has bushings, unlike the 28-29's with bearings.
If you give me a penny for my thoughts and I give my two cents worth, then someone is making money on that deal!
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 05-01-2012, 03:58 PM   #3
Roadster Rich
Some 1930's also have bearings. Mine is an April car and has bearings in the generator. I think this is close to the last month of production before they changed to bushings.
Roadster Rich is offline   Reply With Quote
Old 05-01-2012, 04:10 PM   #4
ford1
if the generator has the oil caps it needs oil about every 500 miles, it only needs 2 or 3 drops of 3n1 or sewing machine oil, dont over oil if you do it will run into the gen, the liter the oil the better it runs into the bushing which is very porous which lets the oil run thru it to lube the gen shaft
ford1 is offline   Reply With Quote
Old 05-01-2012, 04:25 PM   #5
Doug in NJ
Doug in NJ's Avatar
Isn't the front bearing a ball bearing on all models?
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 05-01-2012, 06:12 PM   #6
ctlikon0712
Yes, my mistake, thanks Doug, was thinking of a different Gen.
Old 05-01-2012, 08:40 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
The generator pictured with 2 wires coming out of the case, rather than a stud is a Model B, but will work fine and gets oiled the same as the Model A Autolite style.
Powerhouse generators have a large grease pocket and don't get relubed until the next rebuild.
Old 05-02-2012, 02:33 PM   #8
Tom Wesenberg
I agree with Jeff, and that's why I always suggest rebuilding the 5 bolt-on's before trusting the car to trips.
Generator
Starter
Carb
Water pump
Distributor
Old 05-02-2012, 05:27 PM   #9
Jerry Parr WI
Jerry Parr WI's Avatar
Almost all. Some have had modern sealed front bearings installed. That one does not look like a recent rebuild.
Jerry Parr WI is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
