Old 04-04-2012, 05:41 PM   #1
Contenderizer
Contenderizer's Avatar
Default Alignment Camber Problem
Newbe here. Recently purchased a 29 Pick-up and the RF wheel is clearly miss-aligned. Looking from the front, the top of the wheel is leaning to the outside of the vehicle and tire wear is much more prominent on the outside edge of the tire. The left front wheel looks normal and tire wear is even.
The vehicle handles and drives fine, but obviously I have a problem. The books I have tell me how to adjust toe-in and caster, but camber seems to be fixed (?). Any suggestions as to what I should look for to correct this problem. Bearings seem OK.
Thanks in advance
Contenderizer is offline   Reply With Quote
Old 04-04-2012, 05:50 PM   #2
Stinch
Stinch's Avatar
Default Re: Alignment Camber Problem
My first thought is a bent axle.
Rich
E30 68-B Cabriolet
Stinch's Ford Model A Site
Stinch is offline   Reply With Quote
Old 04-04-2012, 06:22 PM   #3
Ron in Quincy
Ron in Quincy's Avatar
I agree with Rich, you probable have an axel that is bent at the problem end. This is not uncommon problem as hitting chuck holes and curbs over the years often effects the axel.
Ron
Ron in Quincy is offline   Reply With Quote
Old 04-04-2012, 06:23 PM   #4
J Franklin
J Franklin's Avatar
The axle can be straightened, make sure you give the shop the proper data from new.
Old 04-04-2012, 06:41 PM   #5
ctlikon0712
ctlikon0712's Avatar
Kevin in NJ has a nice website. There he has many tech articles, here is one of his just on that subject, if your a doit yourselfer.....
http://home.comcast.net/~68c/Front_a...aightening.htm
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 04-04-2012, 08:07 PM   #6
Stinch
Stinch's Avatar
Great information on Kevin's web site. Discovered my axle was bent back on the right side with the bend to the left of the spring perch. Armed with the information and measuring tools from Kevin's site, I took it to my machinist who used an 80-100 ton press to bend it back to specification. Cost me $80.
Rich
E30 68-B Cabriolet
Old 04-04-2012, 10:07 PM   #7
1931 flamingo
1931 flamingo's Avatar
A large truck or spring facility, or front end shop can probably 'form" it on the car w/out dis-assembly.
Paul in CT
Old 04-05-2012, 12:42 PM   #8
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I had one once like that and it was a bent spindle probably from slamming a curb sideways at some time. I would say to check the spindle first, if ok then I would look for a good axle. I bought a nice axle awhile ago for $30.
Barry B./ Ma. is offline   Reply With Quote
Old 04-06-2012, 09:21 AM   #9
Contenderizer
Thank you all.
If I am looking for a replacement axle, what shall I look for? Are all axles (except AA) the same? Are they stamped for identification?
Old 04-06-2012, 09:48 AM   #10
Mike
Mike's Avatar
I had the same problem on a early 28 roadster pick up, and it was a bent spindle.
mike
Mike is offline   Reply With Quote
Old 04-06-2012, 06:43 PM   #11
Barry B./ Ma.
Originally Posted by Contenderizer View Post
Thank you all.
AA's are a much heavier axle. Good A axles are plentiful, sight down the length for straigtness and check the bores for a good snug fit on the kingpins. I brought a good kingpin with me to check fit when I bought mine.
Thread Tools
Display Modes
