Old 12-02-2011, 03:34 PM   #1
modela@aol.com
modela@aol.com's Avatar
Default Ruckstell model a ford transmission overdrive 3 speed
Just saw this on EBay. Item # 330650403152
RUCKSTELL MODEL A FORD TRANSMISSION OVERDRIVE 3 SPEED
I must admit that I haven't seen one of these before. They have also started to discuss it on the T Forum..
modela@aol.com is offline   Reply With Quote
Old 12-02-2011, 05:39 PM   #2
CarlG
CarlG's Avatar
Default Re: Ruckstell model a ford transmission overdrive 3 speed
The tag on it says it's a "Dual High" which does not match the seller's description.
Old 12-02-2011, 06:03 PM   #3
azmodela
Look at the original advertisements from the era, they were advertised as a "dual high" transmission. Everything in the ebay add is correct.
azmodela is offline   Reply With Quote
Old 12-02-2011, 07:57 PM   #4
SteveB31
SteveB31's Avatar
We installed one of those Ruxtell transmissions in a Model A several years ago. I have to admit, I never checked the 3rd gear ratio. 2nd gear was quite a bit higher ratio then the stock Ford 2nd gear. The one we installed was NOS, and drove nice and quiet. The car we installed it in had a Twin -X two speed rear end, and 3.54 gears, and the car cruised at 75 effortlessly with the Twin X in overdrive. I have been involved with Model A Fords for 30 years, and have seen a handful of these transmissions. My only worry about owning one is a lack of available parts should it break. Just my 2 cents.....
Steve Becker
Berts Model A Center
Denver,CO
www.modelastore.com
SteveB31 is offline   Reply With Quote
Old 12-02-2011, 08:43 PM   #5
modela@aol.com
A Google search found a couple of 1931 ads on the Ruxstell overdrive transmission from Popular Science magazine.
http://books.google.com/books?id=9Cc...rdrive&f=false
http://books.google.com/books?id=n-M...rdrive&f=false
Old 12-04-2011, 03:17 PM   #6
mikewort
Thought I would "Chime in" on this discussion. I have the Ruckstell transmission on Ebay for sale right now. This has been looked at by a few Ford enthusiasts and authorities, they all agree, this is one of the real Ruckstell transmissions. Saturday a Ford historian came down to my location from Detroit to inspect and photograph this item. He was in agreement, it's the real deal. This trans. is one that you remove your existing trans. and replace this with yours. The meaning of "Dual High" refers to this. 2nd gear in the Ruckstell is higher than the stock 2nd in a Ford Trans. and then 3rd in the Ruckstell is 25% overdrive which in the stock Ford Trans 3rd would be direct. This would be the "Dual High" meaning that both top gears in the Ruckstell are higher than the top two of the std. Ford. Again, this is a great item, great find and all looks to be in original and in very good condition.
mikewort is offline   Reply With Quote
Old 12-05-2011, 07:28 PM   #7
Bruce Lancaster
So in modern terminology, it could be termed close-ratio rather than OD.
I have a little manual for this but no trans...
Bruce Lancaster is offline   Reply With Quote
Old 12-05-2011, 08:45 PM   #8
Keith True
Keith True's Avatar
It is still overdrive,top gear is 25% higher than stock.I think it is termed dual high because second is higher also.I know of two,one is in a car that is stored away,and the other is in a garage that the owner planned to use at some point.I have never been able to get near either one of them.
Keith True is online now   Reply With Quote
Old 12-06-2011, 12:12 AM   #9
azmodela
Anything less than 1:1.0 is an 'overdrive' gear/ratio. So a 1:.89 is an overdrive gear. Stock A's are 1:1 for third, or 'direct drive'.
"Close ratio" is simply two gears that are closely spaced together regardless of them being an overdrive or under drive ratio. 1:1 for 3rd gear and 1:.89 for 4th gear are considered a close ratio gearing. 1:3.45 for 3rd and 1:2.90 for 4th are also close ratio. Close ratio trans are more common in 4, 5, and 6 speeds where you have enough gears to keep the engine in it's performance range while still achieving a decent high end speed.
Old 12-06-2011, 11:19 AM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I have made an Excel spreadsheet to use as a comparison. Click HERE to open this in a spreadsheet file and you can use this to compare a stock gear ratio transmission to this transmission. You can also use this to substitute a 3.25 or 3.54 ratio instead of a stock 3.78 ratio to see the speed and RPM differences.
The problem is I cannot upload this as an attachmenthere. Therefore here is a direct link if the other one gives you problems:
www.model-a-ford.com/Ruckstell_3_Speed_Comparison.xlsx
BRENT in 10-uh-C
...(...Finally Updated!! )
Last edited by BRENT in 10-uh-C; 12-06-2011 at 02:17 PM. Reason: To add URL link for spreadsheet
Old 12-06-2011, 11:26 AM   #11
CarlG
CarlG's Avatar
Brent,
Link comes up "Page Not Found"
Old 12-06-2011, 12:23 PM   #12
Dick Deegan
Dick Deegan's Avatar
Mine opened up in Excel with some fiddling around on my part.
Dick
Dick Deegan is offline   Reply With Quote
Old 12-06-2011, 05:06 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
I don't have the latest version of excell so I can't see it.
Old 12-06-2011, 05:36 PM   #14
Kirby1374
Kirby1374's Avatar
Wow, It looks like the Ruckstell really evens out the rpm shift points
Kirby1374 is offline   Reply With Quote
Old 12-06-2011, 05:44 PM   #15
BRENT in 10-uh-C
For the skeptics that feel like a 3.27 rear end gear ratio is too much for a stock Model A engine, this Ruckstell transmission should be an "eye-opener"!!
Mike, I made 3 PDF versions (3.78, 3.54, & 3.27 ratios) and attached it for comparison. You can't play with ratios numbers, or RPMs with this PDF copy but at least you can see it.
File Type: pdf Ruckstell_3_Speed_Comparison_3.54ratio.pdf (48.7 KB, 24 views)
File Type: pdf Ruckstell_3_Speed_Comparison_3.27ratio.pdf (48.7 KB, 35 views)
BRENT in 10-uh-C
Old 12-06-2011, 05:53 PM   #16
Mike V. Florida
Thank you
Old 12-06-2011, 07:42 PM   #17
CarlG
CarlG's Avatar
Brent:
What are the first and second gear ratios coming out of the transmission, nevermind what the rear end is?
Old 12-10-2011, 07:59 AM   #18
Joop
Joop's Avatar
Sold for
$5,232.99
Roster Keeper
The A 400-A Group
Looking to find SIMMONS High Compression head and 1930/31 DRAKE Steering Wheel
Ford400a@aol.com
Joop is offline   Reply With Quote
Old 12-10-2011, 10:43 AM   #19
Jim Parker Toronto
Jim Parker Toronto's Avatar
WOW, I have to wonder how many of these were made and if there is any more around!! Worth keeping an eye open for them......
Jim Parker Toronto is offline   Reply With Quote
Old 12-10-2011, 10:58 AM   #20
85930tudor
85930tudor's Avatar
Send a message via Yahoo to 85930tudor
Thanks Brent . Great info once again...Dave
85930tudor is offline   Reply With Quote
Old 12-10-2011, 04:18 PM   #21
BRENT in 10-uh-C
Originally Posted by Joop View Post
Sold for
$5,232.99
Earlier I publicly acknowledged that I had been agonzing with whether to try to be the highest bidder on this transmission ...or Roger's old Bus body, --and I even made a post about it HERE as I figured both items would cost about the same money to purchase. After much consideration I believe I have comfort now in saying I am very happy the high bidder on that transmission is the winner in lieu of me. Congrats to him on a wonderful purchase!
BRENT in 10-uh-C
Thread Tools
Display Modes
