Thread Tools Search this Thread Display Modes
Old 11-29-2011, 02:58 AM   #1
sturgis 39
Default 1936 Ford Mechanical Brakes
A friend has a 36 Ford with mechanical brakes. Does the emergency brake apply the front and rear brakes or is something wrong?
sturgis 39 is offline   Reply With Quote
Old 11-29-2011, 04:15 AM   #2
Don Rogers
Don Rogers's Avatar
Default Re: 1936 Ford Mechanical Brakes
Both the brake pedal and the emergency brake lever operate the brake cross shaft mechanism, and that in turn operates both the front and rear brakes.
Don Rogers is offline   Reply With Quote
Old 11-29-2011, 07:58 AM   #3
sturgis 39
Thanks for the drawing.
Old 04-05-2012, 11:14 AM   #4
sturgis 39
Will the wide five brake drums from a 36 work on a 39 Ford with wide five drums with hydraulic brakes.
Old 04-05-2012, 11:40 AM   #5
Bruce Lancaster
Front drum has wrong offset to swap with '37-9, rear drum was replaced in service by '37-9 so it probably swaps fine the other way too.
Bruce Lancaster is offline   Reply With Quote
Old 06-26-2012, 09:42 AM   #6
fryguy
Bruce, how about the front wide five drums from 37-39 are they interchangable as well? Say a wide five front drum from a mechanical 37 and a wide five drum from a 39 juice, can they be swapped? How about the shoes?
Fryguy
fryguy is offline   Reply With Quote
Old 06-26-2012, 09:51 AM   #7
Bruce Lancaster
'37-9 drums are interchangeable, both front ones and rears fit mech and hydraulics.
'37-9 rears are the service replacement for '36 rear, and the '37-9 front would be what you want when converting a '36.
Shoes would be different from hydraulic...entirely different brake design in there.
Old 07-01-2012, 10:32 AM   #8
fryguy
Thanks Bruce for taking the time, this helps immensely
Search this Thread:
Advanced Search
Display Modes
