Old 07-16-2011, 12:53 PM   #1
Chuck
Chuck's Avatar
Smile Slow Speedometer and Odometer
The speedometer and odometer readings on my newly restored 1929 tudor are about 50% of what they should be compared to my GPS.
I would appreciate any suggestions on a solution.
Thanks,
Chuck
Chuck
Chuck is offline   Reply With Quote
Old 07-16-2011, 12:57 PM   #2
Modelakid31
Modelakid31's Avatar
Send a message via AIM to Modelakid31
Default Re: Slow Speedometer and Odometer
Did you change any of the gears in the rear end?
Mike C. AKA Modelakid
Model a's are a DRUG and I am a USER.
"Promoting Model A Youth with every step I take!"
My Model A youth site
www.modelakid.com [updated on: ]
Modelakid31 is offline   Reply With Quote
Old 07-16-2011, 01:00 PM   #3
Bob Johnson
Bob Johnson's Avatar
First check that you have a MPH and not a KPH (Kilometers) speedometer. Look at the 0 on the speedometer, is there a KILO in the center of the 0?
If you do not have a KILO speedometer then the only thing I can think of is that your rearend, tires, speedometer gear in the driveline are incorrect.
Bob
Bob Johnson is offline   Reply With Quote
Old 07-16-2011, 03:15 PM   #4
Chuck
Chuck's Avatar
I have a 3.54 differential and a 17 tooth speedometer gear with 21 in tires.
Chuck
Old 07-17-2011, 12:10 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
I believe that 3.78 is standard rear end. The 3.54 is a high speed rear end.
A 17 tooth gear is needed for 21" tires and your cars rear end.
Mike V. Florida is online now   Reply With Quote
Old 07-17-2011, 03:46 PM   #6
Patrick L.
Patrick L.'s Avatar
It appear your drive gear is correct.. I'm wondering about the settings on your GPS.. Kilometers 58% to MPH and Knots are 15%..
Old 07-17-2011, 04:54 PM   #7
Tom Endy
Tom Endy's Avatar
My thoughts are that if the error factor is 50%, the problem is not gear ratios, but possibly a faulty speedometer.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-26-2011, 09:14 PM   #8
Chuck
Chuck's Avatar
I finally found the problem. The square end of speedometer cable I purchased from Cushman Speedometers was too short and was not completely engaging the speedometer. I purchased a speedometer cable from Snyders and it works perfectly. See picture to see the difference in the length of the square end. The gold colored cable was from Cushman and the black colored cable was from Snyders.
Chuck
Thread Tools
Display Modes
