Thread Tools Search this Thread Display Modes
Old 06-05-2010, 04:11 PM   #1
s1b
Default Model T frames
Im sorry to ask such a simple question, but,
Are there any differences on T frames. Im looking for one for a 26-27 and want to make sure I get the right frame.
s1b is offline   Reply With Quote
Old 06-05-2010, 05:52 PM   #2
Roadster62
Roadster62's Avatar
Default Re: Model T frames
All questions are good ones! Yes, there is an EARLY '26 frame and the more common later one. They both have the stamped steel front fender mounts, but the rear crossmembers differ. The EARLY one does not hace the flange at the bottom, just a U shape like the 09-25 rear crossmember. the common 26-27 has a flange and looks more like a Model A rear crossmember. Lots of other EARLY features on the '26 but that is for later.
Roadster62 is offline   Reply With Quote
Old 06-05-2010, 07:01 PM   #3
tmodelman
tmodelman's Avatar
Typical '26 rear crossmember, the pancake hassler shocks are aftermarket accessory
tmodelman is offline   Reply With Quote
Old 06-05-2010, 08:34 PM   #4
s1b
So is it safe to say the frames are the same except for the rear crossmember?
I heard that the frames are the same from 1911-1927? (except for the rear crossmember)
Old 06-05-2010, 08:48 PM   #5
Roadster62
Roadster62's Avatar
1914-25 are the same. 09-12 had short rear crossmembers that ended inside the rails and had forged brackets for the rear fenders.
Old 06-05-2010, 09:00 PM   #6
Rowdy
Rowdy's Avatar
14-16 did not have holes for the battery box. 25 had a 2 rivit quadrant. Also some differences to attaching the rb braces. I do not have my book here or I could look up wich years used which style. Rod
Rebabbitted Model A Block for sale: http://www.fordbarn.com/forum/showthread.php?t=99916
Can deliver as far East as Colfax, Ia on May 22nd. Had to reschedule the trip due to weather.
Rowdy is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
