Thread Tools Search this Thread Display Modes
Old 06-05-2010, 04:05 PM   #1
palmaceae
palmaceae's Avatar
Default Checking oil
How far down does the dip stick go, meaning all the way to the "O" on the dip stick to the block, or just where the metal comes together on the dip stick? What I am trying to say is how far does the dip stick go into the oil pan?
Hope that makes sense, I just want to make sure I have the correct amount of oil in the oil pan.
Thank you,
1929 Ford Model A Tudor Sedan
palmaceae is offline   Reply With Quote
Old 06-05-2010, 04:24 PM   #2
Ed Saniewski
Ed Saniewski's Avatar
Default Re: Checking oil
All the way down. On my engines I don't keep the oil at the Full mark, the oil seems to seek a level around half way. If I fill it up it seems to just leak out.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 06-05-2010, 04:43 PM   #3
V4F
V4F's Avatar
all the way in ....................... steve
V4F
"HOT IRONS" CC
V4F is offline   Reply With Quote
Old 06-05-2010, 08:38 PM   #4
Bill Steiner
Yes all the way in, I keep mine just off the full mark. After an oil change about 4 1/2 qt in it. Bill
Bill Steiner is offline   Reply With Quote
Old 06-05-2010, 09:03 PM   #5
palmaceae
palmaceae's Avatar
Thanks everyone!
Old 06-05-2010, 10:51 PM   #6
Dusty
Dusty's Avatar
Mine does the samething, if I fill it to the full mark it will run out until it reaches about an eight of an inch or so below the full mark. At that point although it stills drips some it will pretty much hold there.
dusty
Dusty is offline   Reply With Quote
Old 06-05-2010, 11:18 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Change the oil but in 4 1/2 quarts and check the dip stick level mark. You may or may not have an original dip stick so the level mark may be off a little.
Old 06-06-2010, 12:06 PM   #8
Fro
when I got my first A motor an old timer told me that you were supposed to check the oil with the stick out of the block, trust me you dont want to do this, it took me about 30 seconds to figure out that this wasnt right, allot of windage.
Fro is offline   Reply With Quote
Old 06-06-2010, 05:37 PM   #9
John Butts in CT
John Butts in CT's Avatar
Remember that original dipsticks are one-piece... rolled around. Remember to fit the "short" end into the dipstick hole... otherwise you'll always read "low."
John Butts in CT is offline   Reply With Quote
Old 06-06-2010, 10:01 PM   #10
skip
Banned
All the way in, oil to the bottom of the letter "F".
skip is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
