Old 03-01-2011, 01:18 PM   #1
Roger/Sacramento
Roger/Sacramento's Avatar
Default Which penetrating oil is best?
Penetrating Oil Machinist’s Workshop Magazine recently did a test to determine which brand of penetrating oil worked best on rusty bolt / nut combinations. They scientifically rusted the threads on a group of nut/bolt combinations then measured the torque it took to remove the nuts after they had been soaked with various penetrants.
Here are the results….
No Penetrant 516 poundsWD-40 238 poundsPB Blaster 214 poundsLiquid Wrench 127 poundsKano Kroil 106 poundsATF / Acetone 53 pounds
The ATF / Acetone is a homemade machinist’s recipe that has been around for more than sixty years. It is made up of fifty percent Automatic Transmission Fluid and Acetone (acetone… you can buy at any local hardware store). The ATF/Acetone mix proved to be the most effective by far and costs the least amount per use. It was also interesting to note that the Liquid Wrench brand worked almost as good as the Kroil brand which costs about 20 percent more.
I put this information here because… if you are like me… you have tried most of these brands at one time or another and some seemed to work better than others… but there was no real proof…till now.
It also gives you greater respect for those early day machinists who after much trial and error figured out a simple penetrant recipe that works better than anything available today. If you ever wondered what they used before products like WD-40 and Liquid Wrench were available…now you know.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 03-01-2011, 01:59 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Which penetrating oil is best?
That's great but unfortunatly I have never had any 'scientifically rusted' nuts to remove.
Old 03-01-2011, 09:48 PM   #3
Ronnie
Ronnie's Avatar
Sea Foam deep creep is also a good product.
Ronnie
Ronnie is offline   Reply With Quote
Old 03-01-2011, 10:31 PM   #4
felix37
felix37's Avatar
I will have to give the ATF/acetone thing a try!
felix37 is offline   Reply With Quote
Old 03-02-2011, 12:04 AM   #5
Lanny
Lanny's Avatar
ATF evaporates at a very very slow rate, BUT Acetone evaporates super super Fast, so you better keep your mix in an Enclosed container, or keep adding Acetone very very often.
I live on tuff street, the further ya go,
the tuffer they git,
I live in the last house on the block !!!
___________________________________________
You bet ya, I wear the pants in My family --------
So What, if She tells me which ones to wear ?
Lanny is offline   Reply With Quote
Old 03-02-2011, 12:21 AM   #6
Bill S
Aerokroil. Not cheap but it what the machine shops use that work on the old stuff.
Bill S is offline   Reply With Quote
Old 03-02-2011, 02:03 AM   #7
fourfords
fourfords's Avatar
Mouse Milk. Weird name but is very good. Works well in avation too.
fourfords is offline   Reply With Quote
Old 03-02-2011, 05:42 AM   #8
55 dude
55 dude's Avatar
the ATF/ACETONE mix is fantastic!
55 dude is offline   Reply With Quote
Old 03-02-2011, 06:48 AM   #9
mrmoose
mrmoose's Avatar
I like GibbsBrand....it's also a very good corrosion inhibiter.
mrmoose is offline   Reply With Quote
Old 03-02-2011, 09:55 AM   #10
32B
32B's Avatar
have been using the Kroil for years. Dad used to work at a boat shop and they used gallons of it. Works great, but will def try the atf/acetone as I always have both on hand anyway.
32B is offline   Reply With Quote
Old 03-02-2011, 10:37 AM   #11
Frank The Plumber
Calfonex, I'm not sure if it's still made but it worked well.
Frank The Plumber is offline   Reply With Quote
Old 03-02-2011, 10:39 AM   #12
Redneck
Redneck's Avatar
Send a message via AIM to Redneck Send a message via Yahoo to Redneck Send a message via Skype™ to Redneck
I use PB Blaster most of the time . Its may not the best but easy to get and works most of the time.Your local stores has it.
Redneck is offline   Reply With Quote
Old 03-02-2011, 11:06 AM   #13
ajohn
ajohn's Avatar
Nothing,I repeat,Nothing on planet earth will beat Castle thrust.It is hard to find,but amazes everyone who has ever tried it. James
ajohn is offline   Reply With Quote
Old 03-02-2011, 11:55 AM   #14
Cecil/WV
Cecil/WV's Avatar
Something I used to like, but haven't seen for while is CRC 5-56. I think Kroil is probably better, though.
Cecil/WV is offline   Reply With Quote
Old 03-02-2011, 12:25 PM   #15
Mike51Merc
Mike51Merc's Avatar
I use PB Blaster, but that stuff smells nasty!
Mike51Merc is offline   Reply With Quote
Old 03-02-2011, 12:42 PM   #16
Ol' Ron
Ol' Ron's Avatar
I have to say the ATF/Acetone work best for me. Over the past 50 years I've tried most all the penatrents and fount this combination to work best
Old 03-02-2011, 12:42 PM   #17
Tim Ayers
+1 on this.
Old 03-02-2011, 07:06 PM   #18
Bill in Al
Bill in Al's Avatar
knocker-loose by K-N if I remember correctly.
Bill in Al is offline   Reply With Quote
Old 03-02-2011, 07:30 PM   #19
OldDad
OldDad's Avatar
I like the blue wrench, if heat is not an issue. I've also used Liquid Wrench for years to keep things moist while I proceed to snap things off! Sort of like liquid drain cleaners -- pour it in, let it sit for a bit, then go get the snake and clear it out. Of course, it is my inept technique which explains this phenomenon, and no lack of efficacy on the part of these fine products!
OldDad is offline   Reply With Quote
Old 03-03-2011, 02:17 PM   #20
nbrskn
when I worked in KC back in 61 62 we had a product called Motion. Could be used on electrical stuff. Spray a directional switch and sometimes it would work again .
hydrogen peroxide works allso.
nbrskn is offline   Reply With Quote
Old 03-04-2011, 12:10 PM   #21
frenchy dehoux
frenchy dehoux's Avatar
Acetone / ATF is the best nothing else beats it.
Frenchy
frenchy dehoux is offline   Reply With Quote
Old 03-04-2011, 04:38 PM   #22
40fordpu
40fordpu's Avatar
Learn something new everyday. Acetone and ATF huh? I will have to give it a shot but I have found that Kroil is the best stuff on the market. Havent tried everything but most cans you can get at your local. Thanks for the tread
40fordpu is offline   Reply With Quote
Old 03-04-2011, 08:54 PM   #23
Doright
I have used Mouse milk and many of the other mentiond cant claim to like any of them except the Mouse milk.
OH and I will be trying the ATF/Acetone mixture a try you bet thanks for the tip.
http://www.mousemilk.com
Doright is offline   Reply With Quote
Thread Tools
Display Modes
