02-24-2011, 12:36 PM | #1 |
Understanding bolt specifications...
I understand just how to measure a bolt for it's length...you measure the "shaft" length only for length.
But just what are they talking about when a bolt specification is listed as: 3/8---24 NF 2 x 2-1/8 hex head bolt (with cotter hole)? OK: 3/8 is the diameter of the shaft; it has 24 threads to the inch and is considered National Fine (NF); is a hex head bolt; and has a cotter hole on the bottom of the shaft. BUT what is meant by "2 x 2-1/8"? Is it 2 inches long or 2-1/8 inches long or the shaft is 2-1/8 inches long with the cotter hole at the 2 inch mark? Hmmmmmm. Thanks. Pluck |
02-24-2011, 01:36 PM | #2 |
Re: Understanding bolt specifications...
Steve, What context is that used in? I write my shopping lists like that when I need 2 of 2-1/8 bolts could it be 2 is the quantity? just a thought
02-24-2011, 01:50 PM | #3 | |
No, that is just how it is listed in the Ford Parts Price List of Standard Parts in describing A-20968 bolt used to bolt down the radiator...two (2) are used for this purpose and I do not think the "2" in the designation is the amount used. Pluck |
02-24-2011, 02:03 PM | #4 |
The "2 x 2 1/8" dimensions that are given would be for the overall bolt length, at 2.125" and the first dimension of 2" would be from the center of the cotter-pin hole to the extreme point of the bolt/screw thread. Not the actual end of the blot/screw. At least that is the explanation from the S.A.E. Handbook pictured below.
"Son, there are two ways to do this, your way and the right way." Thanks dad. Looking for a copy or reprint of 1932 A.E.A. Universal Catalog of Genuine Electrical Service Parts
02-24-2011, 04:11 PM | #5 |
Steve
I'm on vacation and don't have my handbook with me so I cant quote tolerances but the "2" is the class number. Class 1 is a looser fit in the nut (or tapped hole) Class 2 is slightly tighter and class 3 is tighter still. Class 2 is most frequently used and the fit we are all familiar with. This number does not have to do with the cotter pin hole. Roland |
02-25-2011, 01:55 AM | #6 |
Go to your favorite hardware store and pick up a matching bolt and nut such as 3/8"-24 and screw the nut on half way up the bolt threads. See just how much the nut can be wobbled on the bolt. This hopefully will be a fair example of class 1. Class 3 would have little if any discernible wobble but in any case the contrast between the two would be substantial.
http://www.abarnyard.com/ |
02-25-2011, 10:10 AM | #7 |
Thank you for this clarification...hopefully it helped others.
Pluck |
02-25-2011, 11:19 AM | #8 |
Good info. That explains why a repro. nut will start jumping threads but swapping it out with an old OE will torque down.
Thanks, Pete |
02-25-2011, 12:34 PM | #9 |
Here's some info on thread limits from my favorite supplier.
Thread Limits As Marco and others have frequently noted, tap & die sets tend to have big taps and small dies resulting in loose fits. I buy H3 taps from MSC such as this one which would be used to chase head and manifold stud holes 7/16"-14 bottoming tap I chase threads every day using these taps, and find that they do not cut metal. Often there is still discoloration from rust/dirt left in the threads after chasing. At most they shine up the threads without making chips as the taps from the sets would. Joe
1929 Tudor since 1962 Feather River A's |
