Old 02-22-2011, 09:16 AM   #1
banjobrad
Default Front end alignment
Can one of you guru's out there tell me how much camber there should
be on the front wheels? I have a 29 Roadster with an all new front end.
The engine is installed so most all of its weight is there.
I probably have an angle of 2 to 3 degrees from the vertical out at the top.
B.G.
banjobrad is offline   Reply With Quote
Old 02-22-2011, 11:48 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Front end alignment
According to my 1929 Bear Manual of Wheel & Axle Alignment, on page 22 it calls for 7 of angle at the Spindle Bolt (Kingpin) hole. I think in that day it was called "Pitch", ...but to know for sure I would need to order their new Home Study Course or attend the BEAR SCHOOL in Rock Island, IL.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-22-2011, 12:57 PM   #3
Bill Steiner
Don't think the spinle hole would be the same angle as the camber on the wheel. I have the spec. at my shop and I will look today. 2 to 3 dg sounds like it but not sure. Bill
Bill Steiner is offline   Reply With Quote
Old 02-22-2011, 02:37 PM   #4
gunmetal blue
gunmetal blue's Avatar
Send a message via Yahoo to gunmetal blue
I'm will them I thought it was 3 degrees
gunmetal blue is offline   Reply With Quote
Old 02-22-2011, 04:46 PM   #5
Patrick L.
Patrick L.'s Avatar
Most old solid axle vehicles use .5 - 1.5 degrees positive[out at top]camber.. I don't have access to any of my books,but, if I remember correctly I think Ford wants .5-1.0 degrees.. I know caster should 5 degrees and toe 1/32"-1/16".. The early toe setting of 1/8" didn't work well with paved roads..
Old 02-22-2011, 06:31 PM   #6
Bill Steiner
I ck the service bulletins it said for 21 in wheels it was 1.13 + in at the tire side wall. 19 in would be less. Not sure what the dig. would be. That is a lot of camber. I ck mine at the shop today . At the hub it had 1 dg. +. Have19 in wheel but would not make any dif at the hub. The only way to adj is to bend the axle like we do on twin I beam Ford PU.trucks. The roads we drive on now are a lot different . I don't think it is that critical . This is all my opinion, Take it for what it is worth what you paid for the advice. $ 0, LOL. Bill
Thread Tools
Display Modes
