Old 05-21-2010, 05:21 PM   #1
55 dude
55 dude's Avatar
Default adjusting stock 37' ford brakes
guys, is their a online manual that will show me how to safely adjust 37' ford car brakes? getting ready to buy a stocker that has been off the road for 30 years and i'm not at all familiar with the system.i'm old mopar guy crossing over to "stock ford vehicles" as my 38' truck isn't stock. i'll post a thread of it being brought out of the garage after 30 years, it should be fun!
55 dude is offline   Reply With Quote
Old 05-21-2010, 09:08 PM   #2
55 dude
55 dude's Avatar
Default Re: adjusting stock 37' ford brakes
nobody?
Old 05-21-2010, 11:30 PM   #3
Brendan
Brendan's Avatar
i don't know. i got myself a" ford service bulletins 1932-1937" manual
it is a yellow book has the info in it you need i found it on line i cant remember where
Brendan
Brendan is offline   Reply With Quote
Old 05-22-2010, 05:05 AM   #4
don's 37
don's 37's Avatar
Thumbs up Re: adjusting stock 37' ford brakes
55 dude:
Buy yourself a 1937 1938 Ford Chassis V8 Car Shop Manual. It has the info inside on how to adjust the brakes plus much more! You can find them on ebay or from the Macs catalog. Hope this helps.
Don
don's 37 is offline   Reply With Quote
Old 05-22-2010, 06:59 AM   #5
55 dude
55 dude's Avatar
don thanks! i did find some online info to adjust 38' brakes and i thought a manual would make for some interesting reading. i'm not sure if the car i'm about to purchase has one included and would like to adjust brakes first thing before waking it up after 30 years in the garage, should be fun.
Old 05-22-2010, 07:17 AM   #6
jimTN
You definately need the SB's and will have to carefully check the cables for each wheel. They must move freely or screwed up braking for that wheel.
jimTN is offline   Reply With Quote
Old 05-22-2010, 12:28 PM   #7
55 dude
55 dude's Avatar
SB'S? not familiar with that term, we will make sure everything moves free and is lubed up. been many years since i rode in vehicle with mechanical brakes. grandparents neighbor had 36' pu. and i remember coming to each stop sign "hold on we might stop!" i used to close my eyes whenever i saw a stop sign.
Old 05-22-2010, 12:44 PM   #8
Brendan
Brendan's Avatar
my truck sat for 30 years when i got it home it did not stop, i gave it a quick adjustment , like a modern car that helped. you may have to take things apart and clean thim then lube thim. one thing that helps is to rebuild the cross shaft. it wears out no zerk fittings you will get it to stop good. my 36 stops good and i know that i can get it to stop better, good luck ,Brendan
Old 05-22-2010, 10:09 PM   #9
38 coupe
38 coupe's Avatar
Another thing to check is the bake lining material. In 39 the linings were changed to hard linings with the change to hydraulics. If you put hard linings on mechanical brakes you greatly reduce the effectiveness. Make sure you have woven linings. It made a big difference on my 37.
Old 05-22-2010, 11:08 PM   #10
Gary in Mozarks
Gary in Mozarks's Avatar
SB's are service bulletins
Gary in Mozarks is offline   Reply With Quote
Old 05-23-2010, 12:21 AM   #11
Brendan
Brendan's Avatar
the brakes in my truck are not that bad
Thread Tools
Display Modes
