06-08-2016, 07:37 AM | #1 |
1949/53 Coil Bracket Support NEW REDUCED PRICE
City:
CORAL SPRINGS
State:
Florida
Price:
$15
I have reduced the price from $25 to $15.
Get one for Santa's sled. This is a one piece coil bracket support that bolts to the 49-53 Ford/Merc water pump. By remounting the stock 49-53 coil, it gives both your stock and aluminum heads a “clean, uncluttered” look as the stock coil no longer is bolted to the head. This is especially useful when installing early heads on the 49-53 Ford/Merc engine. Your stock 49-53 Ford/Merc coil bracket bolts to this support with two ¼-20 machine screws. This MIG welded bracket is of sturdy construction and is made of ¼ inch cold rolled steel. The bracket comes with a protective coat of red Rustoleum enamel which you can repaint to match the color of your engine. The first two photos show that bracket attached to an 8BA engine with early heads. Will also work fine with stock heads. The last photo shows the bracket attached to a 51 Merc engine with 51 Merc water pumps. I made one for my engine and thought others might like one also. Postage is extra. I only made 13 of these so don't delay. Have 9 left. No more will be made. Last edited by 19Fordy; 12-23-2016 at 12:18 PM. |
03-26-2017, 11:08 AM | #2 |
Re: 1949/53 Coil Bracket Support NEW REDUCED PRICE
Btt
08-16-2017, 01:20 PM | #3 |
btt
08-20-2017, 05:27 PM | #4 |
Will also work fine with stock heads. The last photo shows the bracket attached to a 51 Merc engine with 51 Merc water pumps. I made one for my engine and thought others might like one also. Postage is extra. I only made 13 of these so don't delay. Have 8 left.[/QUOTE] |
09-05-2017, 12:50 PM | #5 |
btt
01-19-2018, 09:42 AM | #6 |
03-07-2018, 02:13 PM | #7 |
btt
