Old 10-08-2010, 06:56 PM   #1
oldford
Default Does Barr's Radiator Stop Leak reallly work
What do you guys recommend for a small radiator leak. Does barr's really work.
oldford is offline   Reply With Quote
Old 10-08-2010, 07:08 PM   #2
~~Walts37~~
~~Walts37~~'s Avatar
Default Re: Does Barr's Radiator Stop Leak reallly work
I started using barr's leak back in the 50s & never had a reason to use anything else. ~~Walts37~~
~~Walts37~~ is offline   Reply With Quote
Old 10-08-2010, 07:09 PM   #3
pauldeborr
pauldeborr's Avatar
I always tell everyone that asks me about that stuff not to use it or any other kind of stop leak. The stop leak does not know where the hole is at and it sticks to everything causing your cooling system to be less efficient. This is not the problem you want to have on a flathead assuming that is what you have. Best thing would be to have it pressure tested and brazed or patched in some way.
pauldeborr is offline   Reply With Quote
Old 10-08-2010, 07:31 PM   #4
BrianCT
BrianCT's Avatar
I just used the aluminum with cooling additive variety for a weeping head gasket. It worked after driving for 20 minutes. If I have to clean everything out next summer, so be it. At least I can enjoy the next two months. As has been stated elsewhere, Cadillac
has been using it.
Keep on cruising!
BrianCT is offline   Reply With Quote
Old 10-08-2010, 07:59 PM   #5
Lenney
Take it to a radiator shop ( if you still have one in your area, most have closed down) and have it fixed and while your there tell them to take the bottom tank off and rod it out... All Barr's leak will do is clog up your radiator.
Lenney is offline   Reply With Quote
Old 10-08-2010, 08:03 PM   #6
Kube
Kube's Avatar
The nice thing about the aluminum powder is it stays in motion if there are no holes (leaks) to fill. The Barrs, while a good product will eventually settle in somewhere. Perhaps where it could cause cooling problems.
Cadillac started using a form of the aluminum powder back in the 1980's. They had a huge problem with intake manifold leaks. Unbeknown to Cadillac owners that visited the dealer for service, the technicians were advised to add a tablet (GM equivalent of the powder) to every model having these engines regardless of the reason the car was in the shop.
Old 10-08-2010, 08:38 PM   #7
Russ/40
Russ/40's Avatar
Bars is great stuff. Never had any problem with it, and it really works well. If you have a cooling system that is running hot all the time, then fix it. If not hot and you have a leak, go for the Bars.
Russ/40 is offline   Reply With Quote
Old 10-08-2010, 09:28 PM   #8
sellers equipped
I poured some in this that has been sitting since 54 and it stopped the pin hole leaks. Slowly poured it in with water running in. Tank half full, worked great
sellers equipped is offline   Reply With Quote
Old 10-08-2010, 10:23 PM   #9
ajohn
ajohn's Avatar
I had a Mustang with 3.8 V6 engine.It developed a leak between the aluminum water pump housing and the cast iron block.Bars leak fixed what would have been a verrrry costly repair!
ajohn is offline   Reply With Quote
Old 10-08-2010, 10:34 PM   #10
FL&WVMIKE
FL&WVMIKE's Avatar
GM, who posts on the V8 Section, showed a photo, on how the aluminum Barrs, had actually polished the inside of his radiator.
When using the pellet Barrs, it should be disolved in hot water, before putting it into your radiator.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 10-08-2010, 11:03 PM   #11
IVT1
IVT1's Avatar
Yes
Go hard, or Go home
IVT1 is offline   Reply With Quote
Old 10-09-2010, 02:02 PM   #12
Teich
Barr leak does work but as lots say plugs a lot of things that don't need pluging. I use cinnamon or pepper seems to seal the leak and not plug things up, kinda cheap too usuallly in the kitchen! Laurie
Teich is offline   Reply With Quote
Old 10-09-2010, 05:20 PM   #13
JT FORD
JT FORD's Avatar
Yes, it works! I used the brown pellets....
JT FORD is offline   Reply With Quote
Old 10-09-2010, 10:57 PM   #14
f1james
Drove big frightliner.New raditor 600.00 came with small pack of stop leaL AND SAID TO USE? i SEE NOTHING WRONG JUST DONT UES 2 OR 3 TIMES TOO MUCH.
f1james is offline   Reply With Quote
Old 10-10-2010, 01:43 AM   #15
Frank Cowan
Frank Cowan's Avatar
Yes it works. I used it on a 2006 ford explorer that had a radiator leak. Replacing the radiator required evac, disconnect and recharge the ac, flush the transmission fluid and of course replace the radiator... very expensive repair. Bars leaks was $3.79 works great.
Frank Cowan is offline   Reply With Quote
Thread Tools
Display Modes
