06-04-2014, 06:11 PM | #1 |
NAPA part numbers for Model A
I tried to use the "search forum" option with out results. I am looking for a list of Model A parts carried by NAPA Auto parts, i.e. points, condensers, bearings, and any other Model A parts they carry. Please post if you have a list of the Model A NAPA part numbers. Thanks.
06-06-2014, 10:36 PM | #2 |
Re: NAPA part numbers for Model A
Please contact me off-line and I will e-mail you my list.
06-06-2014, 10:49 PM | #3 |
This was from 30Tudor;
So... from the “Many Contributors to Fordbarn” and other miscellaneous sources, and making no representations as to accuracy or completeness, here we go: Electrical: Motorcraft DC-1 Condenser Motorcraft DP104 Point Set Points CS30 Echlin (original style) Points CS751 Echlin (new Ford style) Condenser FA5 Echlin Rotor FA3 Echlin Condenser-Mallory Dist MA3 Echlin Starter Brushes F502 Echlin Spark Plug 561 Champion (Wl6Y) Spark Plug 3X Champion (avail on special order) Coil (6 volt) IC9 Echlin Coil (12 volt) IC14 Echlin (w/built in resistor) Generator Cutout CU1 Echlin Alternator (12 volt) 71273SE OCA (one wire, internal regulator) Battery (6 Vo1t) 7200 Exide Battery (8 Volt) 8201 Exide Battery (12 Volt) 843578 Exide LED Lights Tail light - http://www.unitedpacificind.com/storage/file10.pdf Marker lamps - http://vehiclelight.com/clli.html Light bulbs - http://www.superbrightleds.com Bulbs Taillight Bulb (6 volt) 63 GE Stoplight Bulb (6 volt) 1129 GE Taillight Bulb (12 volt) 89 GE Stoplight Bulb (12 volt) 1073 GE Engine: Overhaul Gasket Set FS800C Victor Head Gasket Set HS800C Victor Intake/Exhaust Gasket MS9800 Victor Head Gasket 800C Victor Valve (Intake & Exhaust) 211-1558 NAPA Engine Valve Spring 212-1001 NAPA Engine Valve Seat Insert (Int) 218-8535 NAPA Engine Valve Seat Insert (Exh) 218-7535 NAPA Engine Piston (Std) 224-2625 NAPA Engine (also avail. .080 over) Piston Pin Bushing 223-3316 NAPA Engine Cylinder Repair Sleeve 226-8024 NAPA Engine Piston Ring Set (std) 506 Perfect Circle K&N Air Filters: To fit Air Maze filter kits suppplied by Model A part's vendors: Part E-9257, Round Air Filter, Height: 5.5 in (140 mm), Inside Diameter: 2 in (51 mm), Outside Diameter: 3.5 in (89 mm) See:http://www.knfilters.com/search/universal.aspx Drive Train: Clutch Disk R604 Rayloc Pressure Plate CA1524 Rayloc Clutch Pilot Bearing 6203-2RSJ NAPA Bearing Clutch Release Bearing N1087 NAPA Bearing Clutch Alignment Tool 675-1626 Balkamp Wheels: Front Wheel Inner Bearing 15118 Timken Front Wheel Inner Race 15250X Timken Front Wheel Outer Bearing 9074 Timken Front Wheel Outer Race 9196 Timken Miscellaneous: Gas Cap for 30-31 703-1020 Balkamp Fan Belt 25-20426 NAPA Belts & Hoses (also try NAPA #5L430 or 5L440 which is 1" longer) Consider an industrial cog belt if you have a generator as it will fit around the smaller pully better - TR22425) Fuel Filter Gasket 730-9510 Balkamp (for glass bowl 30-31) Radiator Hose (1-3/4') 611 NAPA Belts & Hose Radiator Hose- (2”) 613 NAPA Belts & Hose Spare Tire Lock 770-2441 Balkamp Bearings (Courtesy of www.jmodlea.com): PINION BEARINGS [799000Series] Cone (2 used) Ford Number B4211 – Bearing Number 28156 [799085] Pinion Double Cup Ford Number B4616 – Bearing Number 28314D, 28314XD [799086] DIFFERENTIAL BEARINGS Cone Ford Number B4221 – Bearing Number 28156 [799085] Cup Ford Number B4616 – Bearing Number 28317 [799087] MISC. BEARINGS {Ford Number} GENERATOR SHAFT BEARING(FRONT) {A10093} - 6203 2RS
06-07-2014, 08:29 AM | #4 |
Mike,
Thanks for this NAPA parts info. It will be particularly helpful when having a breakdown while away from home. I'll copy the list and keep it in my roadster........Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
06-07-2014, 09:37 AM | #5 |
I believe it is posted in the "sticky" also here...
https://www.fordbarn.com/forum/showth...t=17518&page=7
Wanted: Simmons Super Power Head Craig Likon 1931 150B Last edited by ctlikon0712; 06-07-2014 at 09:44 AM. |
06-07-2014, 09:53 AM | #6 |
Here is a webpage on selecting air filter sizes from The Bert's Model A website, www.Model-a.org: Covers airflow and how to avoid rich mixture caused by air filters and filter sizes. Website is Chris Pelikan's work. Might be nice to add to your listing under airfilters. http://www.modela.org/filtering_air_into_carb.html Last edited by Benson; 06-07-2014 at 10:05 AM. |
06-07-2014, 10:22 AM | #7 |
Thank you all for the info.
Dick M |
09-15-2014, 08:09 PM | #8 |
Does anyone have a NAPA number for the paper element replacement (filter only) for the airmaze?
09-15-2014, 08:17 PM | #9 |
Here is there WEB site I selected 1930, Ford, Model A
http://www.napaonline.com/Catalog/Re...0026%2b2026063 Or if you would like to select the info yourself here is the home site: http://www.napaonline.com
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
09-15-2014, 08:39 PM | #10 |
Is the Motorcraft DP104 point set for an original distributor?
Experience is a cruel teacher. It gives the exam first, then the lesson. |
