Old 07-18-2013, 03:47 PM   #1
Merc Cruzer
Merc Cruzer's Avatar
Default Coil boil
Anyone see a coil boil. Just got back from a test drive after adjsuting the brakes and noticed the coil had bubbles. It is hot outside today.....6 volt system and just checked the voltage and it is charging at 6.5 volts.
Merc Cruzer is offline   Reply With Quote
Old 07-18-2013, 04:35 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Coil boil
Pretty common if not using a dropping resistor before the coil.
The coil is oil filled and typical running voltage is more like 4.5 volts with a dropping resistor before the actual coil.
Usually the coil is vacuum packed with oil and allows for expansion when hot. However the coil is sealed and a leak means breakdown of the seals.
Using two ressitances lowers the wattage to each and lowers the heat....you are lucky it ran you home.....
Had it been one of the newer off shore units it would have died ...
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-18-2013, 06:26 PM   #3
Merc Cruzer
Bubbas:
It has run for over 20 years and just now failed. Picked up a new BW coil, will look for a NOS.
Old 07-18-2013, 06:34 PM   #4
BUBBAS IGNITION
Originally Posted by Merc Cruzer View Post
Bubbas:
Could be it just now had seal fail.
My bet is on a change in primary resistance causing the heat build up.
Running voltage should be less than battery voltage...
[email protected]
Old 07-18-2013, 06:34 PM   #5
ken ct
It also looks like its sitting right on top of the exhaust manifold. I would move it elsewhere. ken ct.
ken ct is offline   Reply With Quote
Old 07-18-2013, 08:19 PM   #6
Merc Cruzer
Ken:
Factory bracket and factory location as far as I can tell. I did pull the new coil up a bit so the bracket is half way up the coil.
Bubba:
The new one in on shore - Mexico
