Old 06-30-2013, 05:34 PM   #1
theodore
theodore's Avatar
Unhappy Help! Brakes pull to left
Need help fast- I rebuilt the brake cylinder on the right rear of my roadster and now it literally dives to the left when braking hard. The brakes are Locheed post war 42-48 brakes with only the top adjustment cams. Long shoe is towards the front and short shoe towards the rear. This is the only cylinder that I worked on so the problem must lie with this wheel.
Please help before I crash
theodore is offline   Reply With Quote
Old 06-30-2013, 05:46 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Help! Brakes pull to left
Me thinks maybe the RRear ISN"T working??
Paul in CT
Old 06-30-2013, 05:49 PM   #3
larrys40
You could have a leaky wheel cylinder.. which causes the brake to grab. Start by pulling the two front wheels and check them out.
Larry S
larrys40 is offline   Reply With Quote
Old 06-30-2013, 05:58 PM   #4
46deluxe
Short shoe should be towards the front and longer shoe on the rear .
46deluxe is offline   Reply With Quote
Old 06-30-2013, 07:29 PM   #5
theodore
theodore's Avatar
Bendix brakes have the long shoe in the rear but locheed brakes have them reversed.
Old 06-30-2013, 07:33 PM   #6
46deluxe
Have you bled the entire brake system of air ?
Old 06-30-2013, 07:34 PM   #7
Bluebell
Pull the drums off both sides, and carefully check they are both sides the same. Usually if one side needs doing, so does the other side.
Bluebell is offline   Reply With Quote
Old 06-30-2013, 07:46 PM   #8
theodore
theodore's Avatar
I checked the front wheel cylinders and didn't see any leakage but I will pull the wheels to check it out, thanks
Old 06-30-2013, 07:50 PM   #9
theodore
theodore's Avatar
Yes, I bled them several times and got all the air out.
