06-20-2013, 09:13 PM | #1 |
Homemade Tools, Clutch Finger Adjustment
Here is another quick easy to make tool that I use to adjust the fingers on the pressure plate. I had to install a new clutch disc and pressure plate yesterday for a club member. As soon as I bolted the new pressure plate and disc to the flywheel I could see the fingers were in too deep. I made this from a short piece of aluminum channel and a 1/4" bolt and lock nut. I use my caliper to set the bolt head .010" under 11/16", then use a .010" feeler gauge to feel when the 6 arms are at the correct height.
I will be making an improved design of this later, which will be easier to use. I'll post pictures after it's made. Notice I like to grease all moving parts. This grease will not get on the disc. |
06-20-2013, 09:45 PM | #2 |
Re: Homemade Tools, Clutch Finger Adjustment
Tom, you need your own TV show.
Home made tools with Tom the tool man. |
06-21-2013, 06:34 AM | #3 |
good idea makes it easy
06-21-2013, 07:04 AM | #4 |
Tom, I have seen this dimension reported as 5/8" as well as the 11/16" number that you use. How do you decide which of these dimension to use. Have I mis-read this information?
Uncle Bud says "too soon old, too late smart!" |
06-21-2013, 07:50 AM | #5 |
Will, I've seen 5/8", 11/16", and 3/4" reported, so I just picked the middle figure of 11/16" as the set point. I have also used 5/8" in the past, and it also works fine.
As the disc wears thinner, the fingers move out, toward to the rear of the car, so 3/4" should also work fine. The main thing is that they all be equal in height. |
06-21-2013, 08:16 AM | #6 |
06-21-2013, 08:26 AM | #7 |
You're welcome.
BTW, I wanted to get a picture of the pressure plate before the customer turned it in for a core, but I didn't have my camera when I removed it. It had some small heat stress cracks as I've see before, but this one also had 2 full depth cracks, one which went all the way across the plate. I hadn't see that before, but I remember hearing on the news back in the 70's about a school bus driver that was killed when the clutch blew apart and part of it went through the floor and hit the driver. |
06-21-2013, 11:17 AM | #8 |
How does one set the finger adjustment for a V8 pressure plate--3 fingers--while it is still in the car, i.e. thru the inspection plate opening? I am not sure it was ever done that way or if it could be done.
06-21-2013, 12:25 PM | #9 |
Tom,
I like it.....how about a dial indicator in a piece of bar stock? Kinda like this, only finished. |
06-21-2013, 03:32 PM | #10 | |
There are a lot of times I wish I had a dial indicator with the dial facing out, instead of to the side. |
06-21-2013, 05:00 PM | #11 |
Tom,
Machined "tube", the correct length, too "0 out" the indicator...simple lathe work. Ya..I know what your saying about the face. When I get some time, I'll post you photos of the ones we have here. |
06-21-2013, 08:25 PM | #12 |
Tom,
You have some great ideas for tools and I love your ingenuity. I was wondering if you either epoxy a magnet on either side or use a piece of steel and magnetize it, that way you could "stick" it on the pressure plate. Red |
06-21-2013, 09:40 PM | #13 | |
Yes, you must be reading my mind because that's part of my plan for the next one. I need to finish a few generators first though. |
06-22-2013, 11:36 PM | #14 |
Weird, I was just checking that today and this thread showed up.
01-08-2014, 08:17 PM | #15 |
Tom W, My V-8 clutch fingers were set at 1/2" +/- 1/16'. I reset them at 5/8" but it took all the adjustment range of the nuts at the tips of the 3 fingers. I had to screw them down tight against the fingers. Is this right?
Also , what is the red grease you are always using? Bill G |
01-08-2014, 08:28 PM | #16 |
I think I need a new clutch in my 31 coupe- do you do house calls to Iowa?
01-08-2014, 09:14 PM | #17 |
Ford specified 11/16" for the finger adjustment
01-08-2014, 11:35 PM | #18 |
Thanks Ron. What book did that picture come from?
Bill, that's Mystik JT-6 High Temp, the only grease I buy. cp5491r, I used to go to Waukee for the great gas engine swap meet each year. I quit going when the price of admission got out of sight. It's only about 2 or 3 hundred miles too far for a house call, but at least it's further south, so it must be warmer than we are having. Geez I love global warming. |
01-09-2014, 08:27 AM | #19 |
Thanks for the picture Tom. I am getting ready to replace a clutch in my spare running gear and will be making one of those tools. Have not seen that Mystic grease in my area. Where do you buy it?
01-09-2014, 11:28 AM | #20 |
Its good to see/hear something official about the height setting. I set them at 5/8" and have also heard the 11/16" and 3/4" setting.
That said, I like Toms tools also. As mentioned before, I turned a piece of round stock to 5/8" and set the heights to equal drag on the round stock. Next one, I'll probably turn a piece to 11/16". |
