Old 06-16-2013, 09:47 PM   #1
Leonard
Default 1938 Ford 221" crank shaft
I am in need of a crank shaft for my 221" flat head V8, peferably a standard one, not one that has been oversized. Does anyone out there have one or know where I can purchase one? Thanks
Leonard is offline   Reply With Quote
Old 06-16-2013, 09:58 PM   #2
flatjack9
flatjack9's Avatar
Default Re: 1938 Ford 221" crank shaft
Need to know the year of the engine.
Old 06-16-2013, 11:09 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I believe 36LB, 37 and early 38, 21 stud engines, would all use the same crankshaft. Not sure the early 24 stud engines would use the same crank. You may want to consider placing a want ad here in the swap section.
John
Old 06-16-2013, 11:12 PM   #4
Leonard
The year of the engine is 1938
Old 06-16-2013, 11:17 PM   #5
Leonard
Old 06-17-2013, 06:34 AM   #6
jimTN
Where are you at Leanard?
jimTN is offline   Reply With Quote
Old 06-17-2013, 08:10 AM   #7
Jack E/NJ
Jack E/NJ's Avatar
Leonard>>>The year of the engine is 1938 >>>
The question, Leonard, is really --- is it a 21-stud or 24-stud engine. Early 38s are the former --- later 38s the latter. I'm not sure if the cranks are the same either?
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 06-17-2013, 09:09 AM   #8
Leonard
I am in Edmonton, Alberta, Canada
Old 06-17-2013, 01:05 PM   #9
Leonard
the engine is a 24 stud engine.
Old 06-17-2013, 02:01 PM   #10
Brian
Brian's Avatar
If the crank snout is the small, short one, the crankshaft is the same 36LB, 37,38 engines.
If the crank snout is the larger, longer one, the crankshaft is the same as 91A, 01A, 11A and 21A engines.
Brian is offline   Reply With Quote
Old 06-17-2013, 02:07 PM   #11
Jack E/NJ
Jack E/NJ's Avatar
These are the crank specs for various engines.
http://vanpeltsales.com/FH_web/flath...ring-specs.htm
Jack E/NJ
Old 06-17-2013, 05:48 PM   #12
Leonard
I need the crankshaft for the 1938 which is:
crankshaft overall length 24.47"
main bearing journal 2.3990"
connecting rod journal 1.9990"
Old 06-17-2013, 06:49 PM   #13
4tford
4tford's Avatar
PM sent
4tford is offline   Reply With Quote
Old 06-17-2013, 07:03 PM   #14
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Those crank spec are the same as 36LB - 37-early 38 Everdently the late 38 24 stud still used the early crank. I thought when they went to 24 stud they went to longer and 2-1/2 main, but I guess not. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 06-17-2013, 11:56 PM   #15
Leonard
I have found a crankshaft.
Thanks everyone
Old 06-18-2013, 10:28 AM   #16
Bruce Lancaster
The short crank 24 stud was '38 only...the long crank came in to support the low mounted fan in '39. Short can be distinguished because nose of crank is close to flush with front of front cover. Also, it would normally have a single row pulley with no snout on pulley, crank nut right back against pulley face. A '39 up with single sheave has a tubular extension on pulley moving the nut out front more.
Bruce Lancaster is offline   Reply With Quote
