Old 03-18-2013, 08:12 PM   #1
ford1948f1
Default No compression
Hi everyone, I have a 1948 ford f1 v8 flathead with no compression on 4 cylinders. I have removed the heads and intake and valves are free, what could cause this. I was told from Previous owner that the truck was running fine with no problems but due to his health condition he had it park for 9 years.
ford1948f1 is offline   Reply With Quote
Old 03-18-2013, 08:20 PM   #2
Rock Hornbuckle
Rock Hornbuckle's Avatar
Default Re: No compression
Are the 4 cylinders on the same bank?
'29 Standard coupe 45-A / whitewalls
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'55 Ford F-100 / 302
'66 1/2 Dodge Charger
'12 SRT8 Challenger Yellow Jacket Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 03-18-2013, 08:51 PM   #3
ford1948f1
No 2,5,6,7 no compression
Old 03-18-2013, 09:01 PM   #4
Rock Hornbuckle
One on passenger bank and three on driver's bank. Engine sat for 9 years. What do the valve seats look like, and what is the compression, zero?
Semper Fidelis
Old 03-18-2013, 09:14 PM   #5
36Bill
36Bill's Avatar
You have to move air to get compression, could it be plugged intake or exhaust?
Bill
36Bill is offline   Reply With Quote
Old 03-18-2013, 09:27 PM   #6
ford1948f1
Valves seem to be fine, the gauge just moves up and down from 0 to 5 psi, I was trying to start it all i would get was backfire threw the carb, I rebuilt the carb.
Old 03-18-2013, 09:29 PM   #7
ford1948f1
How could I clean the valves?
Old 03-18-2013, 09:33 PM   #8
VeryTangled
VeryTangled's Avatar
Hi, Not a motor guy, but if the valves are happy then the rings would be the next likely culprit. I assume you're getting a good fit on the compression gauge.
-VT/Jeff
VeryTangled is offline   Reply With Quote
Old 03-18-2013, 09:54 PM   #9
Rock Hornbuckle
Give us the readings on all 8 cylinders.
Semper Fidelis
Old 03-18-2013, 10:05 PM   #10
ford1948f1
Cylinder 1 100 psi
Cylinder 2 0 psi
Cylinder 3 95 psi
Cylinde 4 95 psi
Cylinder 5 to 7 0 psi
Cylinder 8 90 psi
Old 03-18-2013, 10:25 PM   #11
Rock Hornbuckle
It would seem that your gauge was working, therefor most likely it is the compression rings that need to be replaced. Mic the cylinders, check for wear. You may need to rebuild the engine if the cylinders are worn. How many miles on the engine?
Semper Fidelis
Old 03-18-2013, 11:38 PM   #12
Lanny
Lanny's Avatar
The valve has to mate properly in the valve seat (NO rust or corrosion anywhere)
and make sure the valves arn't burned or compression cannot build.
I live on tuff street, the further ya go,
the tuffer they git,
I live in the last house on the block !!!
___________________________________________
You bet ya, I wear the pants in My family --------
So What, if She tells me which ones to wear ?
Lanny is offline   Reply With Quote
Old 03-19-2013, 01:23 AM   #13
denver9
After sitting so long without running there is a good chance the valves are stuck due to rust and corrosion. I am not familiar with flat head V8's but i assume there is a valve cover on the side of each bank. If so, remove the covers, turn the engine over and see if the valve stems are moving freely. That may reveal the pproblem.
denver9 is offline   Reply With Quote
Old 03-19-2013, 07:52 AM   #14
Mike51Merc
Mike51Merc's Avatar
Zero compression indicates open valves more than bad rings. Bad rings will generate at least some compression.
Mike51Merc is offline   Reply With Quote
Old 03-19-2013, 08:48 AM   #15
chuck stevens
chuck stevens's Avatar
valve covers ...!!!! rocker-arms? Maybe check the ECM, just a thought.
chuck stevens is offline   Reply With Quote
Old 03-19-2013, 09:01 AM   #16
krackerjack1951
krackerjack1951's Avatar
most likely carbon under the valves..pretty common condition....hand rotate the engine ,when each valve is at its highest.a tooth brush type wire brush with a little kerosene or diesel fuel scrub the seats in the block and each troubled valve..clean them up and ck compression again..if the compression improves,you might get away with lapping the valves....poor fuel,,short trips doesnt heat the engine enough to burn off the carbon..on and on!
krackerjack1951 is offline   Reply With Quote
Old 03-19-2013, 09:17 AM   #17
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Those valve covers must be collecter items. Henry Ford is still looking for them. LOL Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 03-19-2013, 09:20 AM   #18
1931 flamingo
1931 flamingo's Avatar
ARDUN.......................
Paul in CT
Old 03-19-2013, 09:42 AM   #19
Mike51Merc
Mike51Merc's Avatar
What's a valve cover?
Old 03-19-2013, 09:47 AM   #20
Ronnie
Ronnie's Avatar
Valve train seems to be where problem lies is.You should always have the correct valve in the compression tester as a tire valve is incorrect.Tire valve is not sensitive enough.
R
Ronnie is offline   Reply With Quote
Old 03-19-2013, 10:06 AM   #21
brien
brien's Avatar
I am with those who are siding on the valve problem. I would recommend an entire valve job since you are going to have to remove the heads to "clean" them anyway.
If I recall, since it has been a long time since I lifted valves out of my V-8, you will likely have to remove the manifolds, as well.
You will need a valve lifter. It is a special tool that compresses the valve spring while you lift out the valve itself from the block.
You can use the present valves so long as when you grind away the carbon deposits, you don't reduce any valve tolerance. Otherwise, go on ebay and find a set of valves...They are likely there.
Btw removing the heads you can also inspect the piston heads as well. This will tell you if the engine has ever been rebuilt. You may see a .40 stamped on the heads of the pistons. If I remember correctly, this means the cylinders were bored out 40 thousands over the initial bore. You would need this information if you replace the piston rings. Do everything that you can while the heads and manifolds are off, you won't regret it.
Btw, be sure to remove the head bolts in the series recommended by Ford. You should get a Ford manual for this since if you don't remove and put them back in the proper sequence, along with the proper torque, you will likely ruin all of your hard work.
Here is a link for the engine manual:
http://www.amazon.com/Complete-Ford-.../dp/1884089119
Here is an illustration of the V-8 FLathead:
http://restoreyourford.com/v860parts.shtml
Good luck
brien is offline   Reply With Quote
Old 03-19-2013, 10:12 AM   #22
denver9
OK, no valve covers, I get it. (I am used to a 4 cyl Model A engine, so lost my perspective a little there) Then take off the intake manifold and look for the valves under there. The point is: look to see if the valves are moving freely with FULL travel. they might be stuck open as several have suggested.
-Denver
Old 03-19-2013, 10:20 AM   #23
Mark Slight
Mark Slight's Avatar
My two cents worth, you may be chasing your tail if you don't remove the engine and inspect it thoroughly. If it sat for 9 years there may be pistion ring and lower end problems that will appear shortly and become costly if not corrected.
Mark
Camp Lejeune NC
Camp Geiger NC 1955-1959!
School of Infantry, Semper Fi, 0311
Mark Slight is offline   Reply With Quote
Old 03-19-2013, 10:28 AM   #24
Tinker
Tinker's Avatar
I agree with the guys saying it's a valve issue. Hey, 9 years and you have some stuck or sticky valves.
I'd want to pull the top end myself (intake, and heads). Then you can get a good look at what you have and which ones are sticking. Hit the valve guides with MMO or whatever solution you prefer and work the valves that are stuck but tapping them in with a softhammer and turning the engine over to raise them up. Time is an essence, and it will take some time and some oil. Best to soak as long as you can stand to let it alone. Couple days.
100psi on a few cylinders is good for a flathead that has been sitting for a decade. So it sounds like you might have a good runner once the valves are free.
Best of luck.
Old 03-19-2013, 10:32 AM   #25
Rock Hornbuckle
You have removed the heads and intake, and the valves are free. Then you post again, saying "valves seem to be fine". Tell us in the finest detail you can, just what the valve seats look like. Any rust, particle build up, crud, etc.
Semper Fidelis
Old 03-19-2013, 10:48 AM   #26
Mike51Merc
Mike51Merc's Avatar
Where have I heard "it ran when parked" before?
Sorry for the jab. Seriously, it sounds like a valve job is in order. You may not even have to replace any parts, but you do need to disassemble, inspect, clean & fix anything that needs fixin'.
Pull the heads and manifold off. Rotate the crank and see what you can see.
Old 03-19-2013, 10:50 AM   #27
Rock Hornbuckle
Mike, he's already pulled the heads and intake.
Semper Fidelis
Thread Tools
Display Modes
