08-17-2023, 07:10 AM | #1 |
Rod knock?
Yesterday we pulled the pan on a friend's 31 Victoria to investigate a nasty engine knock that occurs after warm up, and when accelerating. Engine was rebuilt and rebabbited 5,000 miles ago.
We checked the rod clearances with plastigage. All were within .001" to .0015." However, we could move the rod sideways on the crankshaft journal enough to make a definite knocking sound. Several club members on hand could hear the noise 20 feet away. Cylinders 1 and 2 can be shove sideways about a tenth of an inch. We didn't attempt to check the main bearings. We reassembled the engine and took it for another test run, and same noise after warm up. Definite knock. NOT a tick. None of us are engine experts, so we would welcome some analysis here. Thank you in advance. |
08-17-2023, 07:35 AM | #2 |
Re: Rod knock?
Did you check mains?
08-17-2023, 07:45 AM | #3 |
Re: Rod knock?
Any chance you can post a video of it running?
08-17-2023, 08:01 AM | #4 |
Re: Rod knock?
Video of it running? Good idea. I will forward this thread to the car's owner, and maybe he can do that.
No. We did not check any main bearings yesterday. Jim trailered the car to our house and we put it on my car lift to pull the pan. We are all getting too old to lay on our backs. Then we put it back together and ran the car back on his trailer. All in a days work. |
08-17-2023, 08:03 AM | #5 |
Re: Rod knock?
Bent Rod slamming the rod journal forward and back makes the same "knock" as a loose rod "knock" Check your rod straightness.
08-17-2023, 09:21 AM | #6 |
Re: Rod knock?
Bob Bidonde |
08-17-2023, 10:03 AM | #7 |
Re: Rod knock?
Loose cam gear? Easy to check by inserting the timing peg, lightly will running at a idle to see if sound changes.
08-17-2023, 11:42 AM | #8 |
Re: Rod knock?
If the engine was quiet for 5,000 miles, it's probably not because of the rods. Yes, .010" is more than needed but it shouldn't cause a knock. Loose rods normally are noisy when there is no load on them, such as when cresting a hill, mains will knock under load. Good luck!
08-17-2023, 12:30 PM | #9 |
Re: Rod knock?
Thanks Bob,
Your Dikes manual mentions end play on the crank journal of .008" to .012", plus associated end play on the wrist pin. This engine is worse than that. With the car up on the lift and pan removed, I could shake the #1 and #2 rods back and forth on the journal and get a pretty good clunking sound. Wrist pin side to side clearance was worse than the rod. The gang was not buying my end play theory, but nobody had any better ideas, either. |
08-17-2023, 12:35 PM | #10 |
Re: Rod knock?
Was it it's normal quiet self for the first 4,950 miles?
08-17-2023, 01:11 PM | #11 |
Re: Rod knock?
Yes. Quiet for first 4950 miles.
Plus, on a cold start up, there is no knocking noise at all. It gets noisy after a few miles and continues thereafter. Another thing. There was a sort of gray/black sludge at the bottom of the oil pan with what appeared to be very tiny sparkly particles. Finely ground babbit? We thought so, but as I said earlier, none of us ever made our living rebuilding engines. Just old retired old folks trying to figure out a Model A noise. Another thing. The babbit on #2 rod end cap had a hair line crack. Not separated, but Al, who has better vision than the rest of us spotted the crack. Tomorrow, the owner of the Victoria plans to trailer the car out to the shop that did the engine and give the guy a ride and see what he thinks. When this saga finally ends with a definite solution, I will get back to you guys. All suggestions are taken seriously and I thank you all! |
08-17-2023, 01:16 PM | #12 |
Re: Rod knock?
08-17-2023, 01:38 PM | #13 |
Re: Rod knock?
Carbon build up piston hitting it.
08-17-2023, 01:57 PM | #14 | |
Re: Rod knock?
08-17-2023, 02:49 PM | #15 |
Re: Rod knock?
Did the babbit break or get ground off of #1 and #2 on the sides of the rod bearings? That missing would explain the movement and sparkles.
08-17-2023, 02:52 PM | #16 |
Re: Rod knock?
Let it warm up so it makes the noise. Pull off one brass strip at a time (plug wire on a modern car,....). When the noise stops you have narrowed down your problem. If all 4 of them make no difference it is likely a main, or the can gear.
What did the guys in your club think when they heard it? |
08-17-2023, 02:56 PM | #17 |
Re: Rod knock?
The two cylinder locations with all that side play are well beyond the .008" to .012" range. Con rod bend or twist deflection in the beam can cause rapid wear on the side thrust surfaces. It's either that or the thrust edges of the bearing material cracked and fell away into the pan. The thrust surfaces on that rear main should hold the crank endplay to the .003" or at least very close to that.
The cam bearing bores in the block can wear out over time. Cam bushings are made to allow for repair for that situation. The bores have to be machined to fit if they go beyond max wear specs. They have to be bored on a true center axis since that rear bore tends to wear oblong. There is a Service Bulletin on drilling an oil hole to feed that rear bearing on earlier blocks. Some late ones are already drilled for that. |
08-17-2023, 03:42 PM | #18 | |
Re: Rod knock?
No chunks of babbit in the pan, but the sparkly stuff looked like finely ground babbit. Aluminum cam gear on this car. From underneath, it looked good. Only 5,000 miles on it. Several Model A owners in our club have had the old fiber cam gears fail on trips and leave them stranded. So we are one by one switching to aluminum cam gears, which we have found to be amazingly quiet. I did short out one spark plug at a time with a screwdriver, but no difference in the knocking. If it really is a main bearing, then we will have to pull the engine, etc.,etc. |
08-17-2023, 04:09 PM | #19 |
Re: Rod knock?
5,000 miles. Not very well used.... That's a shame. My last engine lasted about 2,000 miles.
08-17-2023, 04:32 PM | #20 |
Re: Rod knock?
While you're checking the bottom end clearances, don't forget to check the crankshaft thrust surfaces. If clearances there are excessive, it can make a knocking sound there as well.
08-17-2023, 05:12 PM | #21 |
Re: Rod knock?
If you know the engine rebuilder, consult with them. If you don't know then pull the engine and put it on an engine stand. Filter the oil through a milk filter (available at places that sell agriculture feed). See if a magnet picks up the particles. If not then likely babbett.
Take the pan off, take out the pistons and rods. Take the rods to someone who can check that they are straight. Take the main caps off and check the clearance. Move the crank back and forth to check for end (thrust) clearance. Check to see if the cam gear is tight on the camshaft. There should be no perceptible fore and aft movement of the crankshaft. The rod bearings can move fore and aft without issue. Take the pressure plate and clutch disk off and remove the flywheel. Remove the flywheel housing. Remove the crank to inspect the bearing material in the block. Remember to mark the location of every bearing cap, piston, and rod using a punch or small pointed grinder. The marks are traditionally on the cam side. Keep track of the shims. A knock on acceleration is usually a main bearing. A rod knock can be heard by running the engine up to a fast idle and then slowly backing off the throttle. Rod bearing can be ruined by having the ignition too advanced. If the bearings are not bad (broken babbett) they can be taken up by removing shim stock. Use an assembly lube when putting the engine back together. Keep everything super clean and change the oil after 50 to 100 miles.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 08-17-2023 at 05:26 PM. |
08-17-2023, 05:53 PM | #22 |
Re: Rod knock?
Engine rebuilding equipment needs to index from previously machined surfaces.
If the top of the cylinder block was resurfaced, it may no longer be parallel to the bottom surface of the cylinder block. If the cylinders were bored perpendicular to the top surface, the connecting rods will have a fore/aft thrust loading. |
08-17-2023, 06:23 PM | #23 |
Re: Rod knock?
Good point, Terry. The bare block can be put on a mill bed and dial indicator on the opposite surface to see if they are parallel. Or a large granite block can be used instead of the mill with the dial indicator mounted on a rigid arm. Checking to see if the bores are perpendicular is a little more complicated and will require some sophisticated measuring equipment. The quill on the mill might be able to be used with the dial indicator mounted on it and run up and down the cylinders. You can hire companies that will do 4 place measurements of your block.
I guess the simple test is to turn the engine over and see if the rod bearings move back and forth on the crankshaft. If everything is lined up straight they will not move fore and aft.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 08-17-2023 at 06:33 PM. |
08-17-2023, 07:48 PM | #24 |
Re: Rod knock?
Before I pulled that engine I'd pull the side cover off of the cam gear and check it.
Has anyone used a mechanics stethoscope to try to narrow down the location of the knock?
Dave / Lincoln Nebraska |
08-17-2023, 08:01 PM | #25 |
Re: Rod knock?
"Has anyone used a mechanics stethoscope?
Dave: No. The Rockford A's aren't quite that advanced. Jim the owner will be taking the car back to the rebuilder, (who shall remain anonymous) tomorrow or next week and take the guy for a ride. Like Terry Burtz says something could be out of square with this engine. Nkaminar: All good points. Personally, I think that this engine will have to come back out for a thorough examination by someone who knows what they are doing. Stay tuned. |
08-18-2023, 08:46 AM | #26 |
Re: Rod knock?
