07-30-2023, 07:50 AM | #1 |
Tips/tricks for getting seriously stuck pistons out of the block
I'm in the process of tearing down one of the most stuck flatheads I've encountered so far. It's a Merc. 99A block, so I figure it's worth the effort if it turns out to be good. It's so stuck, I had to torch the rods just to get the crank out. No amount of Free All, Kroil or 50/50 mix made a dent into freeing things up.
My question is what are tricks/tips for getting these almost rust welded pistons out of the bores? I believe I read drilling a series of holes in the tops of them to get them to collapse inward. Last thing I want to do after going this far it to break up a bore by man handling things. Any thoughts welcomed. |
07-30-2023, 08:02 AM | #2 |
Re: Tips/tricks for getting seriously stuck pistons out of the block
Take a hole saw and cut a large hole in the top of each piston. That usually releases enough tension you can drive them out by driving down on the wrist pin. An air hammer gives lots of non destructive blows to that area instead of using a BFH.
07-30-2023, 08:12 AM | #3 |
See if you can pop the heads off by knocking from underneath with a long rod. If they don't break with just moderate force use a method like described above. Once the head is gone the rest should move relatively easily. I have cracked a bore by heavy handed hammering on a stuck piston. The head had not been completely removed on that one. Get the crank out by fair means or foul and then attack the pistons one by one. I showed a couple of very heavily seized teardowns in some of my videos.
Mart. |
07-30-2023, 08:24 AM | #4 | |
After using up all of my patience in the distant past, I'd begun to do just as you describe right from the start. Saves me a lot of frustration and gets the task accomplished quickly. The pistons are trash regardless on the method of removal.
07-30-2023, 09:19 AM | #5 |
Makes the most sense to me! The last thing you want is too much application of the BFH - as that can split/ruin a bore.
07-30-2023, 10:33 AM | #6 |
While doing this I had also released the rod caps that I could get a wrench to. This took some weight off the crank. Once I was able to remove the crank I could drive the pistons and rods out with a tool that I made from 2 pieces of 3/8x1 and a chunk of 1x1 for the handle. The tool looks like a tuning fork when its welded together. With the 3/8 bars hitting the piston at the wrist pin ether side of the rod and basically drive it out by the wrist pin but you have to clean the bores out with a hone or sandpaper first or the piston will just bust up.
I am building a 1939 1 ton express Last edited by ActionYobbo; 07-30-2023 at 10:48 AM. Reason: Spelling |
07-30-2023, 11:29 AM | #7 |
Take off what will unbolt, then chuck the whole block assembly into a large drum of water,( YES H2O,) leave it to soak for anything from 3 weeks to 3 months and every so often try tapping the pistons lightly.
I saw this article in an Australian hot rodder magazine and tried it. I have pulled apart complete motors, gearboxes and recently a rusted up back axle. It all came apart with patience. A friend chucked a badly rusted Land rover series one motor into the Kafue river in Zambia, as he didn't believe me, 6 weeks later he took it out the river, took it apart, cleaned all the parts, honed the bores and with a set of new rings, bearing and gaskets it is now running again. Believe me water penetrates and dissolves rust better than any oils. Try it, IT WORKS. Below are pictures of a Model A motor before and 3 weeks later, it was rusted solid, every part was salvaged and this pic of the block was taken just as it came apart, before we even cleaned it properly 282.jpg 281.jpg 283.jpg 292.jpg |
07-30-2023, 12:07 PM | #8 |
Vinegar will do the same thing faster
I am building a 1939 1 ton express |
07-30-2023, 12:29 PM | #9 |
Vinegar even in mild form is acetic acid, given time it will eat anything aluminum, especially if there are copper gaskets in at the same time.
07-30-2023, 01:40 PM | #10 |
https://www.fordbarn.com/forum/showthread.php?t=61058
I have used this method for 20 years. It works. Make sure you use mineral spirits or starter fluid for a grill. |
07-30-2023, 04:43 PM | #11 |
I have always been lucky enough to find unstuck engines. Right now, I am down to my last good block. At 81, I think that's all I need.
Kudos to you guys who bring these things back to life. |
07-30-2023, 06:55 PM | #12 |
Water has worked for me also .
07-30-2023, 08:43 PM | #13 |
If one didn’t need to get right after it, I wonder how Rust911 would work in a leveled. Lock, given time?
I dig coal, which provides motivation for EVs. |
07-31-2023, 05:10 AM | #14 |
Thank you! Viv W #7! Who would'a thunk!
07-31-2023, 06:46 AM | #15 |
i'M GLAD TO SEE YOUR ALL IN GOOD HANDS.
GRAMPS |
08-01-2023, 02:47 PM | #16 |
I have an engine here out of a historically significant car , a PO had trouble getting the edelbrock heads off so put a 1/2” hole saw around some of the studs , ruined heads. Tried to drill the pistons out with a regular drill , went through the side of the bore in two cylinders. Yes there are morons out there.
08-02-2023, 03:57 PM | #17 |
I had a similar problem taking the pistons out of a long stuck 59A block. I tried soaking in ATF, 50/50 mix, PB Blaster etc. I never tried removing the center of the piston tho. What eventually worked was using about a 12” piece of a landscape timber which just happened to fit almost perfectly in the bore and hitting the timber with a 10LB sledge. This was after great frustration and generally being ready to give up. Maybe not the first thing I would try but all 8 pistons came out and no damage to the bores. As my4dv8 stated, there are morons out there! Sometimes we get lucky.
08-02-2023, 04:46 PM | #18 |
Good info
08-03-2023, 12:01 AM | #19 |
I've had success by turning a block of wood the size of the piston, placing it above the piston and tapping the piston out with a big hammer. The force of the hammer blows is evenly distributed over the top of the piston and no damage is done to the piston or the cylinder walls. I've used this method on two engines and both are still running. I reused the pistons and only honed the cylinder walls. Of course I soaked them with ATF/acetone
for quite a while before this. |
08-03-2023, 06:46 AM | #20 | |
Funny, in with my flathead tools is a 2ft piece of an unturned wooden baseball bat. Happens to be just about the same size as the bore. I've used that for pistons that need some help getting going. This pistons though are rust welded to the cylinder walls. This one is honestly the worst I've ever had. As you can see, I had to torch the rods to get the crank out. Last edited by Tim Ayers; 08-03-2023 at 07:39 AM. |
08-03-2023, 09:46 AM | #21 |
Tim, I hope for your sake, you will be more fortunate than I was the last time I'd attempted to save a block that appeared much like yours. After all the effort, a boiling and finally a pressure test, well, that block is now a boat anchor.
08-03-2023, 02:22 PM | #22 |
My problem is aluminum finned heads, some of the head studs have come out, but still stuck. Sharp's heads too !! Newc
08-03-2023, 02:30 PM | #23 |
Use an 11/16" deep hole saw on the offending studs and then use properly sized aluminum tube to bush the holes. This actually improves the stability of freshly installed heads as the holes are usually pretty sloppy from the factory.
08-03-2023, 05:09 PM | #24 | |
I'm kind of thinking this block will end up like your experiences. I'm going to give it a go since I'm so deep into it. Tim |
