12-11-2011, 04:39 PM | #1 |
Speedway one piece front crank seal?
Anybody use Speedway's one piece front crank seal with good results? Before I completely close the engine up am having second thoughts about this seal; have used the VEO one piece on my '36 with good results. Can't remember why I got the Speedway version.
12-11-2011, 04:41 PM | #2 |
Re: Speedway one piece front crank seal?
If the Speedway item is the one that's made of rubber, then that's the one to use. I've had good luck with them and find they conform better than the item with the aluminum shell. JMO
Jim |
12-11-2011, 05:13 PM | #3 |
Thanks Jim, it is the one piece all rubber one; I'll close it up and move on. Bob
12-11-2011, 05:15 PM | #4 |
The one I used needed more silicone than I was comfortable with to hold it in the top cover, but it sealed very well. Never leaked a drop out the front, but I never parked it facing down hill either.
12-11-2011, 06:00 PM | #5 |
I use the original. Never had one leak.
12-11-2011, 06:25 PM | #6 |
Alan |
12-11-2011, 06:42 PM | #7 | |
The result was the seal sat too low. This made the timing cover push it down on the crankshaft, causing the lip of the seal to open up beneath the shaft... translating into a giant leak. The cure was to "shave" the outside of the seal until it was able to go all the way into the timing cover. Since the seal could then float, it was also able to center itself on the shaft providing the correct seal all around it. A generous amount of RTV was used during installation for good measure. After all the bolts were torqued, the RTV eventually cured, and the seal was secured in the ideal position. Haven't seen a leak since assembling the engine six years ago. |
12-11-2011, 07:13 PM | #8 |
I used one of Speedways .Been 7 years ago ,no problems as of yet .
12-11-2011, 07:55 PM | #9 |
I use the rope. Conforms well, has stood the test of time, doesn't leak. I never heard anyone say "them flatheads are great except for that leaky front seal". I think these new seals were enginered as something to sell, not really to solve a questionable "problem". Just cause it's old doesn't mean it won't work. Just one old guys' opinion.
12-11-2011, 09:24 PM | #10 |
Make sure the wear sleeve on the 8BA crank or the seal surface on the 59ab does not have a big groove worn in it. The seal work fine. Walt
12-12-2011, 02:49 PM | #11 |
walt as i understand the i piece front seal on a 8ba should have the smooth spacer behind the crank pulley trev
12-12-2011, 03:13 PM | #12 |
TREV --- Many guys have reported using the stock spacer with the spiral groove and have had no leakage as a result. Seems to go against nature, but there you are
12-12-2011, 03:20 PM | #13 |
12-13-2011, 05:29 PM | #14 |
richard how are ypou ?whats happening to daisey mae
12-13-2011, 09:42 PM | #15 |
Daisy Mae
Hi, Trev. I'll be brief here and e-mail you more later. Daisy Mae has evolved to the point where she is simply pure pleasure to drive. I just acquired a terrific 3.54 rear end that I'll use in place of the 4.10 when I go on road trips... although I'm already getting 21.3 mph with the 4.10! Going to be interesting to see the difference.
What are you up to? |
12-13-2011, 11:00 PM | #16 |
Trev, I read that you must use a "smooth" spacer in one of my assembly books also. The book was written in collaboration with a Canadian machine shop that made custom smooth sleeves; I thought they were trying to sell me something as no one else mentioned it in their assembly books.
12-14-2011, 09:49 AM | #17 |
I have always used the OEM seals and have yet to have a problem. Like others have stated... "If it ain't broke, why fix it"?
12-14-2011, 10:05 AM | #18 | |
12-14-2011, 11:12 AM | #19 |
Hi All; I tried welding up the oil pan breather with a pipe coupling, and ran a hose to a pcv valve. All leaks stopped as soon as the crankcase pressure went negative. On an old used engine. later Newc
12-14-2011, 08:10 PM | #20 |
The crankcase must still be vented when useing a PCV valve.
