09-12-2013, 07:45 AM | #1 |
Fuel line size ?
Working on a late '31 with a Tillotson (if it matters). My fuel lines are a cobbled-together mess of mismatched pipe, AN, and brass fittings (former owner was an airplane guy). I plan to straighten out the mess, but in the meantime I have a few questions:
Will 1/4" tube be adequate to run the car at speed? If not, will it work for stationary testing? Will an aftermarket fuel bowl that has 1/8" pipe threads in and out restrict fuel flow? What size fittings work in the fuel shut-off and carb? |
09-12-2013, 08:50 AM | #2 |
Re: Fuel line size ?
The repro fuel line I bought from one of the suppliers is 1/4" OD. I expect it would work fine (haven't used mine yet). Sorry, can't help wit the other measurements, off hand.
Steve |
09-12-2013, 10:07 AM | #3 |
a 1/4" line will work just fine, go for it!
09-12-2013, 10:15 AM | #4 |
1/4" steel line as the others have said. Available at any local parts place. You'll need about 2.5' but buy 3' so you have some extra. DON'T use copper unless you have a good fire extiguisher.
09-12-2013, 03:03 PM | #5 |
What about the carb and fuel outlet?? NOTHING at the hardware store seems to fit those threads. are they 5/16 flare?
09-12-2013, 04:06 PM | #6 |
Heres what you need: http://parts.modelastore.com/show_Product.asp?ID=3892 |
09-12-2013, 05:05 PM | #7 |
The thread is 1/2 X 20 tpi it is a special fitting you can get from any model A parts supplier. You can also order the correct fuel lines. JMO.
09-12-2013, 05:09 PM | #8 |
The fuel line should not be flaired. The fitting threads are 1/2 X 20 . Ferrules are used with the fittings as Tiny says above.
09-12-2013, 05:11 PM | #9 |
Sorry, I'm a little slow. Got a phone call when I was in the middle of my post
09-12-2013, 10:27 PM | #10 | |
FWIW, thread size for 5/16" flare is 1/2"x 20tpi, too...might explain prior owner's use of flared male to 1/8" pipe adapter in the fuel shut-off Snyder's has a kit for late 31's without side-bowl carb...I know that should work, but I don't like the glass bowl hangs from the lines in their illustration. I also can't drive to their store and look at it before I buy. Last edited by racer32; 09-12-2013 at 11:00 PM. |
09-12-2013, 11:18 PM | #11 | |
09-12-2013, 11:26 PM | #12 |
The same fuel line and fittings fit both Tillotson, Zenith and all of the other upodraft carbs made for the model A that I know of. The same fittings and ferrules also work with glass bowl sediment bowl , cast iron sediment bulb and the cast side bowl used with the 1931 models. I've used steel brake lines from local parts houses as well as copper tubing with never a problem. Problems with copper tubing is highly over rated.
