03-21-2015, 05:10 AM | #1 |
Oval Speedometer/Odometer Question
I have an oval speedometer. The speedometer works fine but the odometer does not. Any suggestions as to where to start to fix this?
Thanks |
03-21-2015, 10:28 AM | #2 |
Re: Oval Speedometer/Odometer Question
PRG999 - It is very likely that a gear on the speedometer is not meshing. It could be one of several that ultimately drive the odometer. Also, the reset knob that allows you to reset the trip odometer to "zero" could be the problem too.
I am going to send you a "Word" document that illustrates how to rebuild an oval speedometer. I used it to rebuild mind, and it has worked perfectly ever sense. Let me know you received it.
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
03-21-2015, 10:58 AM | #3 |
Ron/IA, you don't by any any chance have one for a round speedometer do you? I have the same problem in my 31 Coupe. Actually, I could use both.
03-21-2015, 05:20 PM | #4 | |
1929 Coupe 1930 Coupe 1935 Ford 5 window coupe |
03-21-2015, 08:26 PM | #5 |
I'm no expert, but had the same problem. Something in the odometer wheels jammed, causing the copper colored gear to spin on its shaft. I freed up the wheels and used a drill motor to run them for quite awhile, and they seemed fine. I put some J B Weld on the gear and the shaft, and it's worked fine for the past 500 miles.
UPDATE: After a few hundred more miles, the J B Weld failed. The copper gear is back to spinning on the shaft. Thought about solder, but now the speedometer isn't working either. I'm giving up, and going to send it off for a rebuild. Last edited by Fred S; 07-06-2015 at 09:45 PM. |
03-22-2015, 02:51 PM | #6 |
I originally downloaded it from a chapter's web site in Oregon (I think). I would be happy to send it to you by email. PM me you email address. Thanks, Ron/IA PS. the document talks about the oval speedometer. I have not seen on for the round speedometer.
07-05-2015, 11:10 PM | #7 |
I would love a copy of the word document if you have it available. I'm about to tackle this project next for my car. I would love to get it reset to zero (stuck at 99,999) and record my history with the car
07-06-2015, 12:17 AM | #8 |
Yep, I have the same problem and want one too.
07-06-2015, 12:17 AM | #9 |
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
07-06-2015, 01:28 AM | #10 | |
In the 70's when I worked at the GM dealership, it was legal to turn the odometer to zero on used cars, but not legal to lower the mileage by any other amount. The boss had me set some to zero, but after working there for about a year the law was changed and any tampering with the odometer became illegal. In the 80's a customer with a year old car with about 40,000 miles wanted a new speedometer installed, even though his worked perfectly. I knew what he was up to, so I set the new speedometer assembly to the same mileage shown on his old unit. The customer was really pissed because he wanted to drive the car for a few thousand miles and sell it as a low mileage car. He was a friend of the boss, so he complained and the boss had me set it back to zero. |
07-06-2015, 02:25 AM | #11 |
Ron/IA - Its not top secret, but the info is in a Word document that I have not been successful putting here.
Ron, newer versions of Word will allow you to save documents as a PDF or send it to me and I will convert it for you.
I Love Anything That Turns Money Into Noise |
07-06-2015, 08:32 AM | #12 |
Go to Bob Johnsonss Model A House and click on technical, then to speedometer articles on how to disassemble & repair speedos. Sounds like the rollover tang on the odometer tenths wheel has broken off because of dried, hard grease.
07-06-2015, 10:18 AM | #13 | |
07-06-2015, 11:38 AM | #14 |
Here is the link to the Beaver Chapter and Gordon Fishers handout for Model a Ford Speedometers.
Handouts courtesy of THE BEAVER CHAPTER, MAFCA Portland, Oregon. Article and Sketches by Gordon Fischer. Copyright 6-12-94
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
07-07-2015, 05:57 AM | #15 |
That is a great write-up and a great thing to have. The main shaft binds up and you have to remove it to clean it up and lube it. Tough job and you can really screw things up. Do it as a last resort. Take it all apart before you try to push the shaft off of that beveled gear and out of the body. You will have to push that gear back on and that is not easy. Good luck.
07-07-2015, 12:58 PM | #16 |
Adjusting the odo while driving can also damage it. Set your odo while at a standstill.
07-07-2015, 06:23 PM | #17 |
07-31-2018, 07:28 PM | #18 |
Ron/ia. I know this is an old post but if there is any chance you still have the doc could you please pm it to me
--------------------------------------------------------------- If it was easy everyone would be doing it /Tony |
07-31-2018, 07:58 PM | #19 | |
Here is the link to the Beaver Chapter and Gordon Fishers handout for Model a Ford Speedometers. Handouts courtesy of THE BEAVER CHAPTER, MAFCA Portland, Oregon. Article and Sketches by Gordon Fischer. Copyright 6-12-94 http://www.modelahouse.com/tech/spee...r/fischer.html
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 07-31-2018 at 10:34 PM. |
07-31-2018, 10:04 PM | #20 |
