08-29-2018, 05:21 AM | #1 |
1933 dash cluster machined cover reproduction?
Is there a quality manufacturer for this machined-turned panel cover?
08-29-2018, 05:51 AM | #2 |
Re: 1933 dash cluster machined cover reproduction?
Not to my knowledge.I know someone that can engine turn it for you.He is in CO.I had him do mine.
08-29-2018, 06:47 AM | #3 |
There are several out there that can refinish the "engine turning" on these dash inserts, If you do a "search" here on the barn I know "several" have recommended and used a company/guy that is at Hershey every year and I "think" is actually a Buick specialist up in the Northeast???? But the search will also show a few others as well!!!
08-29-2018, 06:49 AM | #4 |
Just did a "search" under "Engine turning for 33 dash insert" and the "First" post has all the info for you!!!
08-29-2018, 07:23 AM | #5 |
Lets play before you have a meltdown so you understand the process. If you have a
drill press clamp a piece on aluminum chuck up a pencil with eraser. Mark out lines on the plate with pencil/sharpie. Try fine valve grinding compound on the eraser and lower the quill now you should see a pattern on the work then go to the next mark. All marks are overlapped. Chucked wood dowels work fine. If you have access to a mill that 10 times easier. I say this cause its nice to know how its done. play with it sam |
08-29-2018, 12:06 PM | #6 |
Tom Correct computer generated asymmetric pattern, copper plate, nickel plate, engine turned and finally chrome plated. Last edited by hotcoupe; 08-29-2018 at 12:37 PM. |
08-29-2018, 12:08 PM | #7 |
Nice!
08-29-2018, 12:47 PM | #8 |
Beautiful work HotCoupe.
08-29-2018, 03:49 PM | #9 |
Here's how I did one out of stainless; I admire that one of hotcoupe a lot !
http://myplace.frontier.com/~wgmumaw...umentpanel.htm |
08-29-2018, 04:15 PM | #10 |
Thank you all for your generosities!
Much appreciated - Pat |
08-29-2018, 05:10 PM | #11 |
Thank you. I have not one to turn at this point! These grateful replies will surely take care of that.
Pat |
08-29-2018, 05:21 PM | #12 |
Thank you, HotCoupe. You would have made Henry grin for sure. I am presently w/o a V-8 or '4'. Wanted to be sure these panel covers are still available.
Pat |
08-29-2018, 05:25 PM | #13 |
Thanks much , Rockfla.
Sincerely, Pat |
08-31-2018, 11:21 PM | #14 |
I can vouch for hotcoupe... he did one for me and it is stunning!
08-31-2018, 11:42 PM | #15 |
Its been several years but I looked in a hot rod magazine and saw custom, multiple gauge machine turned panels for '33's. I called them and asked if they could make a stock panel. They said yes. For under a $100.00 I had a perfect, stock '33 insert panel. -For what its worth.
09-01-2018, 01:17 AM | #16 |
Nice work, need to try it for a piece of trim on an old 1950's era Craftsman Joiner.
09-01-2018, 05:47 AM | #17 |
Thank you, Four Fords.
Pat |
09-01-2018, 03:48 PM | #18 |
09-01-2018, 07:20 PM | #19 |
Carl, the chrome plating is the last step in the process.
Tom |
