11-30-2015, 12:01 PM | #1 |
ID manifolds for 46-48 engine in 41
11-30-2015, 12:13 PM | #2 |
Re: ID manifolds for 46-48 engine in 41
There should be a casting part # on each manifold.
It's probably where you can't see it without using a mirror or "rubbing" it using pencil and paper. Get that number and you will know for sure. Last edited by 19Fordy; 11-30-2015 at 12:18 PM. |
11-30-2015, 01:40 PM | #3 |
Looks like a 59 series engine with 37-41 exhaust manifolds to me. 41s should have the fan on the crank.
11-30-2015, 03:55 PM | #4 |
I agree. Could be a 1947 Ford engine like this one that was removed from a 41 Ford coupe last week. Post a photo of the distributor if possible.
11-30-2015, 04:10 PM | #5 |
Also, note the CHANGED direction of the anti-chatter rods as seen in your pics, as well as in this pic, and Jim's pic. DD
11-30-2015, 04:22 PM | #6 |
Did any other Ford engines use those forward facing chatter rods? |
11-30-2015, 04:57 PM | #7 |
Seems I remember the '41-'47s (at least), and most-likely the '48s, too. DD
11-30-2015, 07:18 PM | #8 |
11-30-2015, 07:25 PM | #9 |
That block is later than '41. The ports for the exhaust manifolds should be "extruded" about 1/4" on a '41 block.
