06-22-2011, 11:45 PM | #1 |
6 volt 2 speed wiper motor
I have a 31 cabriolet (68B) I want wipers (2 speed)that I can open my windshield. My system is still 6 volts Any ideas? mike 828 926 5212
06-23-2011, 12:53 AM | #2 |
Re: 6 volt 2 speed wiper motor
From what I ahve heard, if you go with the modern electric wiper motor (12V?) then I don't think you can open your windshield. Otherwise you are going to have to find an original electric.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
06-23-2011, 01:11 AM | #3 |
Check out the first sticky:
WINDSHIELD WIPERS 3. www.newportwipers.com Electric "aftermarket" Wipers They claim that the windshield tips out normally, and although they are 12v, they also have an inverter to use for 6v applications. They are 2-speed, with an option for intermittent. |
06-23-2011, 01:41 AM | #4 |
Put in a turn signal relay thing to make the wiper intermittent!
06-23-2011, 03:54 AM | #5 |
I use rain x and never have to turn the wippers on .
06-23-2011, 05:55 AM | #6 |
Every month I see an ad in the Model A News for Model A Wiper Service. They sell parts and also (I think) sell units outright ($375 to $465 depending on model and year). I haven't purchased one but you may want to consider that as an option. http://www.modelawipers.com/order.html Supergnat |
06-23-2011, 05:00 PM | #7 |
Mike's sells a wiper motor that can work on your 6V system. With the motor installed on the inside you can still open the windshield about two inches if you use a later model spring loaded wiper arm. You can get the motor, arm, blade, wiring----the whole enchilada for about 75 bucks. I've always found that two inches is really all you need to open the windshield. The motor from Mike's uses a 4 amp fuse. JMHO
Jack
Cincinnati, Ohio |
07-28-2011, 08:24 PM | #8 | |
03-13-2012, 07:38 PM | #9 |
Jack 29 you said Mike.s sell them how do you get to Mike,s on line.Rick
03-13-2012, 09:41 PM | #10 |
03-13-2012, 11:49 PM | #11 |
The spring loaded wiper arm and blade that I used on mine came from a vintage
VW beetle. I "borrowed" the wiper arm and blade from my '59 VW. Works great. Jack
Cincinnati, Ohio |
03-14-2012, 05:35 AM | #12 |
Snyders has new 12 volt and 6 volt wiper motor, blade and arm that mounts as an original vacuum motor on the windshield frame. It uses arm and blade that are being reproduced for original electric motors. Will clear visor, etc and allow full swing of windshield.. It is in their new catalog which will be mailed out soon. Also on their website.. I think the part number is A-17507-6 Saw it in their store.
03-14-2012, 02:14 PM | #13 |
Del,
The Syder system will work, but my experience with this system is that it is inferior to a spring loaded blade, especially in a good wind. The wiper arm does not hug the windshield nearly as well. The only way I would not use the spring loaded arm would be if I wanted a fine point car. My car is no trailer queen and is driven in all kinds of wind and rain. Been there, done that. Jack
Cincinnati, Ohio |
03-14-2012, 04:40 PM | #14 |
This system has only been on the market for a week.. might give it a chance. Myself, I rely on rain-x and a vacuum motor. Been there, done that, got the CD and the Teeshirt
03-14-2012, 06:58 PM | #15 |
Heck, I can't compete with the "T" shirt! The shirt trumps all of the other options.
Jack
Cincinnati, Ohio |
03-15-2012, 09:55 AM | #16 |
Thank,s every one for the come back,RICK rain x is great but need some kinda wiper for the state of Mass.
03-15-2012, 10:11 AM | #17 |
I agree with Rick in Mass, RainX is nice, but if you DRIVE your car----NOTHING beats
a good wiper. Jack
Cincinnati, Ohio |
