Old 04-27-2013, 09:05 PM   #1
Mike Peters
Mike Peters's Avatar
Default Late 31 Ford Script Coil
I bought this coil at a local swap yesterday. JS sez July 31 to end of production. Put it on a car this morning and no spark, and it gets warm. Shorted windings. Only gave 2 and a half bucks for it, so no big deal. Is there anyone who can dissassemble and rewind ignition coils? Thanks
Mike Peters is offline   Reply With Quote
Old 04-27-2013, 09:11 PM   #2
jw hash
jw hash's Avatar
Default Re: Late 31 Ford Script Coil
that is a 32 coil not Model A, the Model A does not have the oval around the Ford script. other then that they are the same.
jw hash is offline   Reply With Quote
Old 04-27-2013, 09:12 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Measure the primary terminals for ohms. You should have about 1 1/2 ohms, or, if you put it on a 6 volt battery charger, you should have a reading of about 4 amps.
Old 04-27-2013, 09:49 PM   #4
700rpm
700rpm's Avatar
I learn something every day on this site!
Ray Horton, Portland, OR
Old 04-28-2013, 07:18 AM   #5
Mike Peters
So this is a Model B coil? It does have the oval Ford script, and the JS shows a coil WITHOUT the oval. I stand corrected. Thanks Mr Hash.
Tom: I put the ohm meter across the two small terminals and get about 30 ohms. Same reading on a coil on a running car. Tried each terminal to the coil case. No reading at all. What am I doing wrong?
Old 04-28-2013, 01:02 PM   #6
Tom Wesenberg
30 ohms is too many. Try connecting a small charger with an ammeter and see how many amps on 6 volts connected to the two primary terminals. It should read about 4 amps.
Old 04-28-2013, 01:06 PM   #7
Rowdy
I know Skip Haney rebuilds flathead coils, maybe he rebuilds Model A coils as well. His contact info can be found on the flathead forum without too much searching. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 04-29-2013, 09:26 AM   #8
Mike Peters
6v battery charger on the two small terminals reads 2.9 amps. What does that mean?
Old 04-29-2013, 10:06 AM   #9
Tom Wesenberg
That's a bit lower than I'd expect, but should be OK.
Old 04-29-2013, 11:35 AM   #10
Mike Peters
Red face Re: Late 31 Ford Script Coil
Apologies are in order, guys. I also have a rusty 30-31 coil with a huge dent that I tried this morning, and it actually worked! Never tried that one before because it loked so bad. So I thought, this nice looking Ford script coil should work as well. Turns out that it had a lot of crud in the high voltage terminal cap that goes to the distributor cap, so I cleaned it as well as I could with screwdrivers and drill bits, plugged the coil wire back in, and tried it again. Nice spark! Started the engine and it runs OK. So now I feel pretty foolish about running for advice before doing the basic home work. False alarm. I also researched some old theads on the same subject where Tom sez old coils usually work, now matter how bad they look. I can verify that Tom is right. All of my old rusty dented coils will run an engine as is.
