Old 05-01-2012, 01:17 PM   #1
frank long island
frank long island's Avatar
Default wipers
put a new aftermarket harness in the 64 ranchero the wipers were working fine now when i turn the switch on and off they keep running unless i disconnect the power i have it wired as power to top lug of switch the rest is original harness as i said they worked fine. is there a set of contacts in the motor that trigger's park when shut down or is it in the switch HELP!
frank long island is offline   Reply With Quote
Old 05-01-2012, 06:46 PM   #2
rick55
rick55's Avatar
Default Re: wipers
The park circuit feed to the wiper motor is live when the switch is turned off. It is possible that you have connected the harness to the incorrect switch terminal. Have you ever had the wipers working correctly with the new harness fitted? If you have your switch is fritzed. Let us know.
Regards
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 05-01-2012, 07:53 PM   #3
rick55
rick55's Avatar
Default Re: wipers
Sorry the image isn't clearer I found this on another forum.
The power to switch should be connected to the orange/white terminal. If you connect it to any other terminal the wipers will not function correctly off the switch.
Regards
Rick
West Australia
Henry Ford
