Old 06-22-2011, 11:56 PM   #41
BillM
BillM's Avatar
Default Re: Flathead ignition Poll
HEI triggered by Mopar magnetic input (no condenser required ).
MSD cap and rotor;
My web page:
http://myplace.frontier.com/~wgmumaw/
BillM is offline   Reply With Quote
Old 06-23-2011, 05:24 AM   #42
39portlander
39portlander's Avatar
Thumbs up Re: Flathead ignition Poll
Great input. Will get an MSD crab cap and a set of points for the glove box. Don't have a coil to send to skip so I'll get an MSD blaster with my cap.
39portlander is offline   Reply With Quote
Old 06-23-2011, 06:23 AM   #43
ventilo
Bubba-Chevy mechanical advance Distributor, NGK plugs, "blue" Bosch 6 Volt coil, no resistor, all running on 6 Volts in my French flattie
starts on the button - regardless whether hot or cold
ventilo is offline   Reply With Quote
Old 06-23-2011, 08:11 AM   #44
Human Fly
Human Fly's Avatar
Originally Posted by Pete View Post
I have used nothing but Harmon & Collins mags on every flathead I have built or owned since the mid 50's.
I thought 'Mags' are no good for the street as they have no advance.....did i get my wires crossed so to speak??
What is this 'Skip' coil you guys speak of????
Human Fly is offline   Reply With Quote
Old 06-23-2011, 12:44 PM   #45
37 Coupe
37 Coupe's Avatar
My setup is a little different from most posted so I will try to describe it. I have a 59AB in my 37 coupe with a 4 inch crank and a NOS Mercury camshaft with front snout machined for early distributor,Red of Red's header come up with the cam few years back. Distributor is 37-41 style but uses the 11A shaft,cam and weights as 41 Ford would have for more advance which is needed for engine I have . The distributor was built and setup by a guy in Virginia named John Shelor,never see his name on this forum or V8 Club's but he has written several articles in V8 Times about distributors and coil moisture,probably has been over shadowed by Haney coil rebuilds, I think he is a retired electrical engineer,mayby in his eighties. He makes a special point plate and uses a 57 Ford point and a 74 Pinto point in his early Ford distributors,whether it is the availability or he considers them stronger and more dependable I do not know but man it sure runs good, big difference from the stock 68 distributor I first ran. Surprised John's name is never kicked around on forums,he is always busy,too busy to be blowing his own horn on internet I guess. Think he has done a few Great Race setups.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 06-23-2011, 01:37 PM   #46
jbrittonjr
jbrittonjr's Avatar
Original distributor with pertronix module & stock coil.
jbrittonjr is offline   Reply With Quote
Old 06-23-2011, 03:27 PM   #47
39portlander
George "skip" Haney e-mail: [email protected]. If your looking to have your water pumps done, he's the guy as well. He has a set up for pressurizing the radiator also. Ad's in the latest May/June V8 times. If your not a member yet, what are you waitin for
Old 06-23-2011, 04:30 PM   #48
Ol' Ron
Ol' Ron's Avatar
Bill M I like your distributor, This type of modification to the old Crab makes it a much better unit than the MSD unit because it still uses a vacuum component for distributo advance under load and cruise. Those that run without vacuum have a rich mixture during cruise witch waste fuel and contributes to cylinder ware, by washing the cylinder walls with excess gas
Old 06-23-2011, 04:58 PM   #49
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Most mags comes with or without advance. Many run the Vertex with advance and they run pretty well at fixed advance on a flathead .....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 06-23-2011, 06:32 PM   #50
Human Fly
Human Fly's Avatar
THanks for the e-mail.......but whats the deal with the coil?? This is the forst i have heard of it and a few seem to run it. Whats special about it?
Thanks Bubba, good to know I can run a Mag on the street and the lack of advance will not effect performance.
Old 06-23-2011, 09:09 PM   #51
coolcoupe
coolcoupe's Avatar
Originally Posted by 41ford1 View Post
Mallory electronic crab on a 59A engine. It was in place when the I bought the truck. No problems with it for 5 years.
Did you mention you have a electronic on your 59A engine? Been looking for that set-up for awhile. Coolcoupe
coolcoupe is offline   Reply With Quote
Old 06-23-2011, 09:13 PM   #52
coolcoupe
coolcoupe's Avatar
Can you still get the electronic conversion for a 6volt 59 engine? Moe
Old 06-23-2011, 09:17 PM   #53
coolcoupe
coolcoupe's Avatar
Is your set-up on a 8ba or 59a engine ?Thanks Moe
Old 06-23-2011, 09:27 PM   #54
coolcoupe
coolcoupe's Avatar
BillM, Where can I get that dizzy thats shown ? Thanks Moe
Old 06-23-2011, 09:37 PM   #55
Zeke...PA
Zeke...PA's Avatar
8BA with a crab distributor. Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 06-24-2011, 12:28 AM   #56
BillM
BillM's Avatar
It's basically a DIY deal. Too many mods to the pickup and selective fit to bore the reluctor to fit the cam to make it kit of parts to install on any distributor. And I don't have the time to do it for others.
See my website for the details on how I did it. I tried to include enough info for others to duplicate it; although it requires the use of a lathe at the least.
My web page:
Old 06-24-2011, 07:27 AM   #57
rick r
rick r's Avatar
early 1980's chrysler 318 electronic on my 8ba. $ 50 at the bone yard and a couple of hours on my old logan lathe and it works great.
rick r is offline   Reply With Quote
Old 06-24-2011, 03:12 PM   #58
Ken Crans
Ken Crans's Avatar
Bubbas rebuilt,Deep sea Diver style dizzy w/points and Pertronix 6 volt 50,000 volt coil. Purrs... Ken
Ken Crans is offline   Reply With Quote
