07-23-2011, 05:13 AM | #1 |
1933/34 ford chassis identification?.
Does any one know who i would get in contact with to identify a chassis by its number?.not sure if the chassis i have is 33 or 34?. Is there a differance?. thanks Martin
07-23-2011, 06:55 AM | #2 |
Re: 1933/34 ford chassis identification?.
The numbers might define it, but if they are near or at the transition from the '33 models to the '34 models, they might not. The physical characteristics of what you have may be a more reliable indicator.
For example, how do the front shock absorbers mount on the frame, inside the frame or outside? (If there's a large hole between the two shock mounting bolt holes, the shock mounts inside the frame which suggests that it is a '33 frame; if there's only the two shock mounting bolt holes, the shock mounts outside the frame and it's a '34.) |
07-23-2011, 10:09 AM | #3 | |
The first pic is 33 - second pic is 34 . The 33 clearly shows the shock hole DavidG talks about . Notice the front crossmembers are way different as are the radiator mounting plates .
07-23-2011, 08:01 AM | #4 |
1933: 18-203,127 to 18-457,477
1934: 18-457478 to 18-1,234,356 |
07-23-2011, 10:02 AM | #5 |
I have 2 chassis.the one that came with the car has been molestered badly (front and rear chassis horns removed,front cross member removed and mustang front end added,rear cross member has large hole cut for coil overs) I started to fix this chassis by removing mustang front end and replaced with original cross member,and replaced the rear with a uncut original,the number on this chassis is *8<->4####1*.but then i found a original rolling right hand drive chassis which i would rather use as it is complete,its numbers are completely differant,*13-f1#####6*.I dont know if there is any differances between the 33-34,but i want to put my 33 coupe body onto what i think is a 34 chassis,i have seen in a M.A.C.S.catalog that the 34 wheel base is 6 inches longer will this cause a proplem with placing the 33 body on a 34 chassis,the front shocks on the rolling chassis are mounted on the out side,thanks Martin
07-23-2011, 10:07 AM | #6 |
[FONT=Comic Sans MS] |
07-23-2011, 10:21 AM | #7 |
yes your right BrianCT about the wheel base being the same,it is the 1933 4 cylinder model that was 6 inches differant.David j thanks for the pics,my molested chassis has the hole where the shocker is but no original cross member came with it,cheers guys learning every day,thanks Martin
07-23-2011, 12:02 PM | #8 | |
33 -34 4cyl & V-8 have the same wheelbase .
07-23-2011, 01:21 PM | #9 |
1933 Chevrolet Mercury series was 107" w/b and the Eagle was 113", you may be thinking of that.
07-23-2011, 01:38 PM | #10 |
Or perhaps recalling that a '33-'34 four-cylinder rear axle is shorter than the V-8 version, but it's not six inches worth. The body will fit any '33-'34 112" wheelbase chassis or frame (they were all 112" except those for the big trucks) without modification to either the body or the frame. A RHD frame that was original to Australia would normally be stamped with a number that begins with either C18F (for V-8s) or BF5 (for fours).
07-23-2011, 04:58 PM | #11 |
Regarding 'features'... The front shock hole is an 'indicator', but not an absolute identification feature. The 'transition' cars, mentioned above, can also have the front shock hole, but originally came with 34 shocks. I have such a car. And, regarding the frame numbers... I've been watching the barn for many years, and have occasionally seen posts where the numbers are discussed. But, I've never seen any documentation that lists the Canadian numbers (by year), the same way that we have a pretty good definition of 33-34 US numbers ???
If one takes a close look at the car that I have, it only leads to confusion, or perhaps, mine is a 'transition' car. It has numerous 33 features, and some 34 features, and excellent indicators that the car is an original car, not pieced together from parts. Examples... Original paint visible on all parts, including doors, tub, hood. Hood is 34, and latch cutouts in cowl appear to be 'factory'. Cowl vent is 33. Original dash is 34. No hood-rest-notches on top of cowl (like 34's have). Doors and window features are 33. One bumper is 33, other is 34. Grille is 34. And, frame has front shock holes, but came with 34 shocks. Fenders appear to have always been black - generally associated with 33, and body-color generally associated with 34 (I know, there can be exceptions.). Just opinion, just observation.... |
07-23-2011, 07:06 PM | #12 |
Here are the Canadian '33-'34 V-8 numbers from their Archives. I forgot that there is letter between the 18 and 'F' in their sequence of numbers for V-8s which were in blocks of 5,000 numbers (the 'F' only used for those engines destined for RHD chassis).
1933 model V-8s: C18H 1 to 5000, C18N 1 to 5000, and C18X 1 to end of model run which was less than 5000 1934 model V-8s: C18A 1 to 5000, and C18E, C18G, C18K, C18L, C18M, C18P, C18S, C18T, and C18X all in blocks of 5,000 engine numbers except C18X which ran to the end of the model run and was less than 5000. For RHD vehicles, an 'F' was added to the prefix (e.g. C18HF). As the original subject is Australia, only the V-8s carried Canadian engine numbers while the fours came from Ford of Britain which used the U.S. numbering system (assigned to Dagenham in blocks of numbers by Dearborn). Speaking of built-in-Canada '33s, unlike in the U.S., body-colored fenders, fender aprons, gas tank cover, and spare tire cover was an inexpensive production option available for their passenger cars. Too bad that option wasn't available in the U.S. as some wish. |
07-23-2011, 09:07 PM | #13 |
David, this is off the subject, but is your Canadian number-list really in the order it was used ?? You seem to say that C18X was used last. The reason for me asking... My car carries the C18XFxxxx number, and if it was assembled towards the end of 1934, I'm really puzzled as to why it has so many 1933 features. Your comment above seems to suggest that my car was assembled VERY near the end of 1934 production (C18XF35xx).
07-23-2011, 11:55 PM | #14 |
Bob,
I could have misread my list and I'll double check it as it is highly unlikely that they used the same prefix (C18X) two model years in a row. Note that C18X was the last '33 series of numbers which would seem to fit your car characteristics of the 'twilight' transition period between the '33 and '34 models. David |
07-24-2011, 10:56 AM | #15 |
Scratch the C18X prefix from the '34 engine number list; it only belongs in the '33 engine number list. Sorry for the confusion.
07-24-2011, 07:41 PM | #16 |
how come my numbers dont match any of the numbers you have supplied?.one chassis is Americain and one is Aussie,thanks Martin
07-24-2011, 11:15 PM | #17 |
In some jurisdictions over the years when a rebuilt engine was installed, a new number was assigned to the vehicle and in some cases, Ford's original numbers were obliterated by law. There are no doubt other possible explanations, such as your one example where the 13 prefix could be 18 with a poorly stamped '8', but Ford was very consistent in applying its own engine numbers to the chassis when the engine was originally installed.
Perhaps your RHD chassis was originally produced in the U.S. and in that case the prefix would be 18F in the case of a V-8 chassis (and in the case of the RHD V-8s, that prefix remained the same throughout both the '33 and '34 model years and simply 18 for LHD V-8s). |
07-25-2011, 12:43 AM | #18 |
The 4 cylinder "propshaft" is shorter, and you turn the gearboxmount 180 degrees to move the engine and gearbox back and forth.
V8 tube on the top. |
07-25-2011, 04:18 PM | #19 |
Does anybody have the serial no breakdown for BF5 cars or Canadian B models? Thanks Manuel in Oz |
07-25-2011, 04:53 PM | #20 |
For 1933 and 1934 (there was no separate series of numbers for 1934 models) the series were: CBT 1 to 5000 and CBW 1 up to (but likely below) 5000.
No records have survived that list the BF5 servies of numbers and as the engines were numbered sequentially with either the B or BF prefix (or BB or BBF), it is likely that such a record was not maintained in the first place. |
