Old 09-23-2017, 12:39 PM   #1
GOW
GOW's Avatar
Default 36 horn button
looked around couldn't an answer. the horn on my 36 works also there are 4 positions you can turn the button....what do or did the different positions do? thanks
GOW is offline   Reply With Quote
Old 09-23-2017, 12:51 PM   #2
Ford coupe
Default Re: 36 horn button
You have off on high beam on low beam and on park lights ..Not in that order but that's it on my 36..
Ford coupe is offline   Reply With Quote
Old 09-23-2017, 01:38 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
In other words, that's your light switch. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-23-2017, 01:44 PM   #4
rotorwrench
rotorwrench's Avatar
Ford used the light switch on the steering wheel for a long time but basically discontinued the practice in 1940.
Old 09-23-2017, 02:31 PM   #5
1stford
1stford's Avatar
Strait up is off. 1 click to the right is parking lights. 1 click to the left is low beams and 2 clicks to the left is high beams.
1stford is offline   Reply With Quote
Old 09-23-2017, 02:32 PM   #6
GOW
GOW's Avatar
that's great info.....thanks
Old 09-23-2017, 02:39 PM   #7
Don Rogers
Don Rogers's Avatar
Here's a diagram of the Light Sw./Horn Button showing the switch positions.
Don Rogers is offline   Reply With Quote
Old 09-23-2017, 02:45 PM   #8
GOW
GOW's Avatar
thanks
