Old 10-30-2021, 10:47 AM   #1
jstrez5
Default Disregard
Disregard.
jstrez5 is offline   Reply With Quote
Old 10-30-2021, 11:01 AM   #2
Kube
Kube's Avatar
Default Re: 1939 Ford Deluxe Sedan door trim
Originally Posted by jstrez5 View Post
I am in need of the interior door trim pieces for my 1939 Ford Deluxe Sedan. The pieces I need are located on the rear inside doors: both left and right side. Some specifics on the pieces...
* Measure approximately 26" long
* Held on with small nails that are welded onto the back of the trim piece
* Attach to the door via the small nails
* Located slightly above the door and window handle
See picture below for reference. Again, I am in need of both driver and passenger rear door pieces.
Thanks!
Jim
All I can tell ya is good luck. Those are in the unobtanium lists.
Unless you are doping a high point restoration, I might suggest you search for narrow stainless trim that is long enough to cut down and hammer the ends to shape.
Seriously, your odds of finding these (stock) are very poor at best.
Plus, you might try posting your ad in the PARTS WANTED section.
Kube is online now   Reply With Quote
