Old 06-27-2015, 10:31 PM   #41
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: How to clean out a fuel line on the car?
Originally Posted by ford38v8 View Post
Hey Bob, Good to see you up and full of vinegar again!
Yep, always good sound advice from Super!
John
Old 06-27-2015, 11:38 PM   #42
Ralph Moore
Ralph Moore's Avatar
This kinda reminds my of someone I knew, he had a pick up that would shudder at a certain speed. He checked the drive line, etc. and ws finally convinced it needed a transmission rebuild(automatic). Rebuilt tranny and $$$$ later, same problem. Someone suggested checking spark plugs, he hadn't done that, sure enough they were really bad.
$24.00 later and it ran great.
Never overlook the simple things.
Ralph Moore is offline   Reply With Quote
Old 06-28-2015, 05:04 PM   #43
Royal Ryser
This has been so much fun! I hope it keeps going.
Royal Ryser is offline   Reply With Quote
Old 06-28-2015, 07:21 PM   #44
Bluebell
So where did this start?
Is it as simple as the fuel pump sucking air at the site glass seal?
Bluebell is offline   Reply With Quote
Old 06-28-2015, 07:28 PM   #45
Old Henry
Old Henry's Avatar
The story started here: https://www.fordbarn.com/forum/showthread.php?t=171201
Then went to here: https://www.fordbarn.com/forum/showthread.php?t=171851
Then here: https://www.fordbarn.com/forum/showthread.php?t=171979
Then this one you're on.
The story will continue . . .
Old 06-28-2015, 07:55 PM   #46
Tinker
Tinker's Avatar
So Craig. What did you find out? 3 threads running now. Just curious on how it turns out... Wonder if this is less about the car or the attention. Not my bag man.
Just a side note. New fuel lines might be a good selling point, even if it doesn't total turn out to be the biggest issue. Nice thing when handing a vehicle off to a buyer anyway.
Best of luck!
Old 06-28-2015, 07:57 PM   #47
Tinker
Tinker's Avatar
But hey I might be on your ignore list!
Old 06-28-2015, 08:02 PM   #48
Old Henry
Old Henry's Avatar
I won't know more until I rebuild the fuel pump when the parts arrive in a few days. Hopefully that will solve the problem without any more fussing with anything.
When I decided to get my 47 back on the road 9 years ago I had to decide what approach I would take between customization and authenticity. I opted for original stock authenticity as much as possible. Part of that commitment was to not replace any part that was still working or could be made to work and, if it absolutely had to be replaced, replace it with NOS first and authentic new replacement part last. I started that engine that had sat for 31 years with all of the original spark plugs, belts, pulleys, pumps, generator, everything except the battery that hadn't lasted sitting 31 years. The video of that first start has had over a million views on YouTube. (Here: https://www.youtube.com/watch?v=wY389S_KUjs) Others have other priorities and enjoy working and tinkering on their cars more than I do and replace parts pursuant to a different philosophy than I do. That's good for them and mine is good for me. Theirs makes them happy and mine makes me happy. I don't condemn them for the way they like to do things and hope none will condemn me because I like to do things differently.
Thus, I won't be replacing the fuel line in the 51 Custom unless absolutely necessary.
Old 06-28-2015, 08:03 PM   #49
Old Henry
Old Henry's Avatar
You are not. I have always enjoyed your posts and you have been a great help to me with many of your suggestions.
Old 06-28-2015, 08:05 PM   #50
Tinker
Tinker's Avatar
You'd be a first! Ha ha.
Old 06-28-2015, 08:07 PM   #51
Old Henry
Old Henry's Avatar
I'm just trying to solve a problem. That's all. Nothing more nor less.
Old 06-28-2015, 08:10 PM   #52
uncle max
uncle max's Avatar
I have a KR Wilson fuel pump holding fixture that you're welcome to borrow if you're in SLC anytime soon. It's like having an extra pair of hands while working on them.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 06-28-2015, 08:31 PM   #53
Mike B
I admire your tenacity, but consider a plugged fuel line (as you were)...there's no way you could get it completely clear and clean...only hope would be replacement.
You'd be pushing crud into the tank, and flowing it back through.
Anyways, I'd take UM up on the offer...extra hands are nice
Mike B is offline   Reply With Quote
Old 06-28-2015, 09:20 PM   #54
Old Henry
Old Henry's Avatar
See post #20. The fuel line is not plugged nor restricted in any way as I had supposed when I started this thread. It may have air leaks but I won't know that until I rebuild the fuel pump and try it.
Old 06-28-2015, 10:21 PM   #55
Lanny
Lanny's Avatar
I had a very slight leak in a fuel line. This was a NEW fuel line that
the previous owner had installed, and I could not find the small leak.
I reversed the hose on my shop vacuum cleaner so it blew air out,
and stuck the hose in my fuel filler. It didn't take long at all to see
exactly where the leak was, as a lite bit of gas started comming
out, just enough to show a definate leak.
The previous owner had drilled a very small hole in the floor under
the rear seat for a clamp to hold wires secure. As luck would have it,
he drilled the hole right into the new gas line, that went under that
part of the floor, and when I blew air into the tank, the gas seeped
out, so I found the leak.
When I took the small screw out, it leaked plenty then, mystery solved.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 06-28-2015, 11:02 PM   #56
Old Henry
Old Henry's Avatar
Great idea! I did that very thing to test gas flow through my fuel line. (See post #20) I will do that again if I'm getting enough air in the line to bother the engine after I rebuild my fuel pump to confirm that there is, indeed, a leak. Whether or not I can find a leak, if there is too much air coming in. I will then replace the fuel line. I've had some great suggestions for doing that and will use them if and when I absolutely have to do that.
Old 07-21-2015, 10:06 AM   #57
Old Henry
Old Henry's Avatar
Drum roll . . . . Envelope please. . . . And the winners are: ford38v8, oldford2, Ross F-1, Tinker, and anyone else that suggested replacing the fuel line. I just did that and it solved the problem. But, I didn't do it until actually diagnosing that such was the problem by doing the winning diagnostic procedure that goes to: 51 MERC-CT for suggesting running the engine on a line from a gas can. I got a nice long piece of clear tubing, hooked it to the fuel pump, ran it through the firewall to a gas can inside the car, and drove it. Worked great and didn't stop or die no matter where I went, how far I went, or how long I drove. That clinched it for me that, even though I wasn't sure what was wrong with the old fuel line, I knew it was the problem. Had it replaced yesterday and works fine now.
Unfortunately, I have discovered another problem - the car is very susceptible to vapor lock. I'm not going to install an electric fuel pump on this car that I'm just trying to sell for the wife of my friend who died. I'm just going to park it in the shade whenever I can and hope I can find someone to blow into the gas tank filler pipe to get it started if it vapor locks.
Old 07-21-2015, 11:28 AM   #58
itslow
itslow's Avatar
This is a good example of why it's wise to start a thread and then continue it instead of creating multiple subsequent ones, or at least include a summary in the initial post of the symptoms and previous remedy attempts. It makes it very difficult to determine the back-story on the newer threads when there's no link back the the prior ones.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 07-21-2015, 12:01 PM   #59
trainguy
trainguy's Avatar
VAPOR LOCK!!! O NO!!! lol
trainguy is offline   Reply With Quote
