06-15-2015, 07:30 PM | #1 |
Wayno goes 136 mph in his belly tanker
Saw this photo on the SCTA Facebook page.
I just thought it might be our own Elmo Rodge from the big cheesy grin on the front so PMed him and, sure enough, it was him. Went 136 mph at El Mirage. Here are some pictures I took of him and his racer in March 2014: Wayne and his car built out of a the belly tank from a WWII airplane. The front axle is from a 30 something Ford. The tires are dragster front tires. The windows were made by an aircraft manufacturer per Wayne's specifications. Entry is through the panel on the roof that opens up. Here's from the rear: Right behind the cockpit is the 15 gallon water tank that holds the water to "cool" the engine for it's short run without a radiator. It has standard Ford rear axle tubes shortened attached to a special differential that has quick change gears on the rear end. The silver tube is for the parachute released by the black cable on top of it. He's fabricated a real cool cover for the tube out of a Ford hub cap (forget which year). The engine is on the stand at the far wall and the transmission is under the plastic at the front end. The cable on this side of the parachute tube is an external shut off. Looking into the cockpit from the left side: The silver knob/lever on the far right releases the parachute by pushing it forward. The 8 ball is the transmission shifter. Above that is the starter button, then ignition, then fuel pump switches. Just ahead of that partially hidden by his knee is the inertia kill switch to shut off the engine in the event of a crash. The steering wheel is removable to get in and out of the cockpit and has a tachometer mounted to the middle of it. The gauge above that is air/fuel mixture. The net below it is to keep Wayne's feet and legs from leaving the vehicle if it crashes. The cockpit from the right side: The red tank above the net is the fire extinguisher for the front end that is activated by the black knob left of his left hand. The silver lever next to that activates the hydraulic brakes. The gauge above his left knee is water temperature. The yellow light above that is a shift indicator for the transmission. Wayne reclining in the driving position: There are pads on each side of his head that just barely clear his helmet to keep his head from getting knocked around if he crashes as well as pads on each side of his shoulders to keep them lined up with his head if he crashes. He looks between his knees out the front window and has some side view through the side ones.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 06-15-2015 at 07:37 PM. |
06-15-2015, 07:35 PM | #2 |
Re: Wayno goes 136 mph in his belly tanker
06-15-2015, 07:37 PM | #3 |
I told him to put a turn signal on it and leave it blinking so everyone would know he's from Utah!
06-15-2015, 10:26 PM | #4 |
Atta boy, Wayno, boy racer.
06-16-2015, 01:18 AM | #5 |
Elmo is the man. Way to go Bro.
Salt Is Good... Mk 9:50 |
06-16-2015, 06:03 AM | #6 |
Wayne's view from the cockpit. Ready for a run on the salt.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
06-16-2015, 07:56 AM | #7 |
Beyond cool! Living the dream.
06-16-2015, 07:59 AM | #8 |
Way to go Wayno! Hope to see you at Bonneville this year ...
06-16-2015, 08:01 AM | #9 |
I A ER WOW GEE COOOOOOOOOOOOOOOOOOL !!!!!
Charlie ny |
06-16-2015, 08:26 AM | #10 |
Hey way no,good fun?,
You need a blower on that, Carol says hi. Lawrie |
06-16-2015, 09:06 AM | #11 |
Very nice! Got any pics of the engine?
06-16-2015, 09:14 AM | #12 |
These were the first real passes with the fuel injection. I'll have some data to look over after I recover from the trip and finish unpacking. There is plenty left in it. Wayno
Life is not a spectator sport. |
06-16-2015, 09:43 AM | #13 |
I met him once!!!
Way to go Wayn--OH!!! |
06-16-2015, 09:51 AM | #14 |
Congrats on your run at 136mph Wayne..........from the Jennings Bros.
06-16-2015, 10:48 AM | #15 |
Right on Mr. Wayno! Ya gotta drive 'em! You take it to the next level
06-16-2015, 12:25 PM | #16 |
Hey, WAY cool Elmo!!
06-16-2015, 01:25 PM | #17 |
yeeeeeehawwwww......keep on havin' fun.....Mike
Thread Tools | |
Display Modes | |
