03-13-2015, 04:28 PM | #1 |
How do these syncro inserts work?
Just received my order from Vanpelt of my transmission parts. I ordered new solid syncro inserts, balls, and springs and got these. He's gone for the day but I want to get the car back on the road tomorrow and haven't a clue how these work. Does anyone?
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 03-13-2015 at 04:34 PM. |
03-13-2015, 04:36 PM | #2 |
Re: How do these syncro inserts work?
Try this video:
https://www.youtube.com/watch?v=MXsRfbOiBhE They go around the hub and the lock rings hold them in, one on each side. |
03-13-2015, 05:01 PM | #3 |
Great video! Thanks Dave
03-13-2015, 05:06 PM | #4 | |
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
03-13-2015, 05:08 PM | #5 |
Yes. Very good. Shows clearly the reason to always replace the brass syncro rings any time the tranny is opened up. They can be worn out without even looking worn out.
03-13-2015, 05:11 PM | #6 |
Lawrie |
03-13-2015, 05:42 PM | #7 |
Henry,
My preference are the solid inserts. I guess Mac figured you would reuse your existing springs and balls. Charlie ny |
03-13-2015, 06:01 PM | #8 |
The plates with no holes work with the C spring rings and are of a different style than the synchro hub that uses the ball bearings with coil springs. The two hubs are different so I don't think they can interchange between types.
The very early 91A transmissions used the spring ring type and then they were discontinued until somewhere in the late 40s. My 49/E51 Merc overdrive transmissions use the spring ring type hub. |
03-13-2015, 06:31 PM | #9 |
I bought this book by Mac. Very informative.
03-13-2015, 07:05 PM | #10 |
Great Video!!!!
03-13-2015, 07:58 PM | #11 |
Diagram of different early Ford syncro styles. Good information on VanPelt's site:
http://www.vanpeltsales.com/FH_web/f...d-synchros.htm |
