Old 04-24-2015, 10:05 AM   #1
duffer
duffer's Avatar
Default Anti freeze
What do you guys run in your radiator? Is anti- freeze bad for our cars? I found some Meijer brand extended life Phosphate-free
Silicate-free formula . Or is just plain water good enough with a rust inhibitor ?
Thanks in advance.
duffer is offline   Reply With Quote
Old 04-24-2015, 10:12 AM   #2
marc hildebrant
marc hildebrant's Avatar
Default Re: Anti freeze
I use the same antifreeze in my Model A as I do in my other cars. I see no reason to treat it different than today's car.
While the transfer of heat is better with water than antifreeze (50-50), the boiling point of antifreeze is higher than water, so it "balances out".
Today's antifreeze have anti-rusting stuff, so why not keep the engine in good shape.
Marc
marc hildebrant is offline   Reply With Quote
Old 04-24-2015, 11:45 AM   #3
Patrick L.
Patrick L.'s Avatar
I'm one that uses distilled water with inhibitor. Anti-freeze only goes in for winter storage.
Old 04-24-2015, 11:48 AM   #4
mshmodela
mshmodela's Avatar
As newbie and a one year of experience, my car mostly sat for 5 years with little use before it was mine --thankfully it had anti-freeze in it... I run 50/50, and thus far have not had any overheating issues...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 04-24-2015, 01:22 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I run 50/50 antifreeze & add a jar of plain old BARS-LEAKS, "JUST IN CASE"-------------------
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-24-2015, 01:25 PM   #6
raprice22
I use ethylene glycol 50/50 in both of my vintage cars for years and they're doing just fine.
Rog
raprice22 is offline   Reply With Quote
Old 04-24-2015, 01:27 PM   #7
ODFever
ODFever's Avatar
I run a 60/40 mix of water/green coolant.
ODFever
1930 Ford Model A Town Sedan "Alyssa"
ODFever is offline   Reply With Quote
Old 04-24-2015, 01:41 PM   #8
JD 1931
JD 1931's Avatar
Original radiator and I run 50/50 Walmart antifreeze , sometimes but not often I add a little bars leak...
JD 1931 is offline   Reply With Quote
Old 04-24-2015, 03:09 PM   #9
40 Deluxe
If running plain water, expect to be caught by surprise with an early fall freeze! So you saved $15.00 on antifreeze. Now what??
Old 04-24-2015, 03:28 PM   #10
Tudortomnz
Tudortomnz's Avatar
Anti freeze can encourage internal leaks if there are any v fine cracks. A friend on the just recent Model A Meet here in southern part of NZ put some in his AA Tow Truck but there was a fine crack in the head which resulted in water in the oil. Drained it all, put clean water in radiator, no more problems.
I have only used water , no anti freeze, but then it only gets dangerously cold in a few certain areas here.
In the old days, previous owner of my Tudor lived in an area that gets heavy frosts ; they put a sack under the engine & on top of the bonnet/hood as the car sat outside.
Today, we would not do that or drain the system if leaving outside?
Tudortomnz is offline   Reply With Quote
Old 04-24-2015, 04:08 PM   #11
Mitch//pa
i use 49 - 51..
Old 04-24-2015, 04:16 PM   #12
Big hammer
49% water or 49% anti we need to know :-)
Old 04-24-2015, 04:27 PM   #13
bobf
Hi Guys
i WORKED IN THE REFRIGERATION GAME FOR OVER 20 YEARS. MY PARTNER AND I EXPERIMENTED ONE TIME AND MIXED ETHYLINE GLYCOL ANTIFREEZE AT 10% WITH WATER AND USING R22,( WHICH HAS A FREEZING POINT OF -40 DEGREES F.) ,THE MIXTURE GOT A LITTLE THICK BUT NEVER SOLIDIFIED AT -40F . WITH THIS IN MIND I USE 25% GLYCOL & WATER IN MY SPORT COUPE WITH NO PROBLEMS
FOR OVER 15 YEARS
BOB F FROM CHILLY ONTARIO
bobf is offline   Reply With Quote
Old 04-24-2015, 07:48 PM   #14
glenn in camino
glenn in camino's Avatar
Anti freeze removes most paints. Powder coated engine pans are OK.
Old 04-24-2015, 08:34 PM   #15
armchair67
Been using standard 50/50 anti freeze in my 31 since I bought it last summer-been driving it daily including through Chicago winters with no issues. When I bought the car I did the vinegar flush which caused me a world of woe by plugging my radiator up to the point I ended up having to replace it. with the new radiator and anti freeze, no issues thought.
armchair67 is offline   Reply With Quote
Old 04-24-2015, 09:19 PM   #16
ian Simpson
Depends where you live. We can get - 40F in a bad winter so all our vehicles run 50/50 good quality anti-freeze and tap water.
When I lived in more temperate climes I used 50/50 good quality anti-freeze and tap water to raise the boiling point and reduce corrosion.
Ian
ian Simpson is offline   Reply With Quote
Old 04-25-2015, 02:34 PM   #17
BILL WILLIAMSON
Vinegar WON'T dissolve big rust flakes. After vinegar cleaning, REMEMBER to backflush the radumator, GOOD, to remove rust flakes that are stuck in the top of the tubes. I backflush my radumator twice a year, & oil my horn, every 3 months!
Bill W.
Old 04-25-2015, 09:19 PM   #18
billwill
Iwont put bars leak in anything I know it stop up a heater core Good luck
billwill is offline   Reply With Quote
Old 04-25-2015, 10:29 PM   #19
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
It was probably partially plugged to begin with.
Old 04-26-2015, 03:36 PM   #20
BILL WILLIAMSON
Dorg here,
Iffin' sumbody mentioned PEANUT BUTTER, sumbody would find sumptin' WRONG with it---------& DON'T use it for STOP-LEAK CUZ I eat it & still have to take a LEAK @ 2:17 A.M!
Buster T.
