06-17-2015, 06:06 PM | #1 |
Water pump packing nut
My water pump may not be the leakless kind since it leaks. I backed the packing nut all the way off and stuck in a new packing from Bert's. How tight should I tighten it up? This is the first time I have done this.
06-17-2015, 07:23 PM | #2 |
Re: Water pump packing nut
Until it stops leaking. Then check it often. Also back the nut off and fill it with waterproof grease.
06-17-2015, 07:32 PM | #3 |
Thanks Glenn.
06-18-2015, 11:56 AM | #4 |
