Old 07-09-2010, 03:35 PM   #41
Straightpipes
Straightpipes's Avatar
Default Re: How many out there run Stromberg 97's
I run two 97's, Thanks Uncle Max. Two years and a lot of miles on them.
Straightpipes is offline   Reply With Quote
Old 07-09-2010, 03:45 PM   #42
Kahuna
Kahuna's Avatar
I've got three
Kahuna is offline   Reply With Quote
Old 07-09-2010, 04:00 PM   #43
Robert/Texas
Robert/Texas's Avatar
I have single 97's on my '34 and '37.
Robert/Texas is offline   Reply With Quote
Old 07-09-2010, 06:18 PM   #44
thunderbirdesq
thunderbirdesq's Avatar
Two old chromies on my flathead...
thunderbirdesq is offline   Reply With Quote
Old 07-09-2010, 09:12 PM   #45
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I have 4 in a row 97s on my 4 carb intake that uncle max set up for me to put on my 276 in my 40, I cain't seem to find time to install them. They look pretty setting my shelf. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 07-09-2010, 11:34 PM   #46
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
One on my '36 pickup
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 07-10-2010, 01:01 AM   #47
ken ct
Quite a stable there there Adam good luck with all of them and safe riding. ken ct.
ken ct is offline   Reply With Quote
Old 07-10-2010, 05:20 AM   #48
ironbuttjohn
ironbuttjohn's Avatar
I got 2 97's
ironbuttjohn is offline   Reply With Quote
Old 07-10-2010, 05:30 AM   #49
Barry WNY
I use one now and also have a 2 setup may try agian someday. BUT if I didn't have any I wouldn't buy any, use the 94's. Carburetors over 50 bucks are out of my league.
Barry WNY is offline   Reply With Quote
Old 07-10-2010, 06:07 AM   #50
2002p51
2002p51's Avatar
Originally Posted by OoltewahSpeedShop View Post
Not trying to be negative, but what is the advantage to the 97 over the Ford 94? I can CLEARLY see the dis-advantage. Price!
I can only speak for myself, but the 94's I've had all ran like crap. I finally went with a 97 from Uncle Max and haven't had to touch it in almost two years.
Worth every penny.
2002p51 is offline   Reply With Quote
Old 07-10-2010, 06:26 PM   #51
metalman
metalman's Avatar
I have 2 97's on the 39 and 3 94's on the motor in the 40 (the one in my avatar).
I'm no expert by any means, been messing with these things for only a couple years but I tend to like the 94's a little better. I didn't think the 94s were any tougher to rebuild and it seemed like it was easier for me to get them running right. Maybe its just the cores I used but my 97s always have leaked some, getting worse it seems the more I drive it. My 94 are still preety fresh but so far no leaks. From a purely looks aspect I prefer how the 97s look.
metalman is offline   Reply With Quote
Old 07-10-2010, 07:06 PM   #52
bdridge
Run an 81 primary and 2- 97's progressive. Bud
bdridge is offline   Reply With Quote
Old 07-10-2010, 10:36 PM   #53
Pete
Pete's Avatar
On a stock engine 94's work fine.
On a performance engine, 97's or better, 48's perfom far better for one BIG reason....They have a bigger venturi.
Floatless bored out 48's can be made to work better than fuel injection on 100% nitro.
I have never seen anyone mention one of the biggest reasons for using any Stromberg carb on here though..THEY SCREECH WHEN YOU OPEN THE THROTTLE.
It sounds like something is happening...94's et al sound stock..Wimp carbs.
See Uncle Max for 48's (cheap plug)
Old 07-12-2010, 11:24 AM   #54
Fox Valley Hot Rods
Nice looking set up!!! I really like your banjo fittings
Originally Posted by Gastrick View Post
I personally like the Stromberg power valves way better than the 94's. I have 4 Strombergs in a row on an OT engine and I'm using two that I got from Max on a flathead for my current project.
This is all I have of my next engine. I still need everything that sits below this ha.
Fox Valley Hot Rods is offline   Reply With Quote
Old 03-01-2013, 03:25 PM   #55
uncle max
uncle max's Avatar
And the beat goes on!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 03-01-2013, 04:11 PM   #56
Pete
Pete's Avatar
With that 4 setup, you will most likely have dehydration and asthma at high rpm.
Old 03-01-2013, 05:51 PM   #57
Walt Dupont--Me.
So.... Is there a performance advantage to the 97, or is it just tradition?
That being said, when did the 94 come along?
I've had flathead engines back to '37 models and none of them had a 97. They all had 94's on them.
Later 38 was the first 94 made by Chanler Groves from then on all Fors had 94's. Walt
Old 03-01-2013, 06:05 PM   #58
Walt Dupont--Me.
I guess some of these replys are old. I've been running 97's 4 in a row on my 276 in my 40 for 2 years. Built by Mad Max. direct linkage, smooth as a smelt, from idel to 5 grand. Walt
Old 03-01-2013, 07:23 PM   #59
Lawson Cox
Lawson Cox's Avatar
Originally Posted by Chet/Ma. View Post
There are all kinds of surveys done on the Ford Barn. So here is one. Who runs the old Stromberg 97 carburetor or more than one on their Flathead? Just how many are still being used to date? I guess even 84's would count. Thanks for looking and taking time to answer. Chet
I run one on my 35 PU.
Old 03-01-2013, 09:34 PM   #60
Randall
Randall's Avatar
[IMG][/IMG]Have two on my Mdl A pu
Randall is offline   Reply With Quote
Thread Tools
Display Modes
