Old 04-08-2011, 05:00 PM   #1
39portlander
39portlander's Avatar
Unhappy Passenger door Alignment Problem..
Driver door closed good for a 39! but my passenger door has a hitch @ the lower hinge before It closes. When closed the 3 rasied lines on the cab do match the 3 raised lines on the door.
I want to fix this problem but not sure what I getting into. Would like a sequence to go by to properly fix/repair or replace lower hinge and have door close good. Any input would be great.
39portlander is offline   Reply With Quote
Old 04-14-2011, 07:59 PM   #2
Dick
Dick's Avatar
Default Re: Passenger door Alignment Problem..
If you'd like some ideas on this email me at [email protected]
I tried to send some possible cures, but ran out of space or time and got logged out. Dick
Dick is offline   Reply With Quote
Old 04-15-2011, 09:15 AM   #3
harry goebel
harry goebel's Avatar
I had this problem with my 36 conv. What I did was make a spacer out of aluminum to fit between the hinge and body. I worked well and all you have to do is touch up the ends with paint.
harry goebel is offline   Reply With Quote
