12-26-2013, 02:38 PM | #1 |
How to read a 1950 F1 VIN Plate off the firewall?
Trying to determine, if possible, the original color of my 1950 F1 pickup from the stampings on the firewall. It reads: 98RC260870 A TL.
Then next to the right of the plate are numbers/letter stamped directly on the firewall 512K1793. Any help would be apprieciated THANKS! |
12-26-2013, 03:02 PM | #2 |
Re: How to read a 1950 F1 VIN Plate off the firewall?
If you can pull the vin plate off you may find the orig color under it. When I restored my 45 truck it was the only place I found good paint.
12-26-2013, 04:02 PM | #3 |
Keep searching on Google and you will eventually find a site that can break down the VIN. or see if the EFV8 club has an official restoration book......Mark
12-26-2013, 05:36 PM | #4 |
12-26-2013, 05:59 PM | #5 |
12-26-2013, 07:14 PM | #6 |
12-26-2013, 07:34 PM | #7 |
Prior to 51, those firewall codes were harder to decipher.
This discussion was a good one. http://www.ford-trucks.com/forums/42...ut-off-47.html There are a few here on the Barn too. Some of the guys that responded on that forum also respond here as well. |
12-26-2013, 07:38 PM | #8 | |
They're pretty easy: 9 - 49 or 50 and your's is close to the cutoff, it was probably a '49 but sold and titled in 50 (if you're sure of the title) 8R - 239 flathead V8 C - half ton pickup 260870 - actual serial number assigned to the truck ATL - Atlanta assembly plant Firewall: 5 - Sheridan Blue exterior color 12K - produced October 12, 1949 (at the time Ford was using the calendar year as model year for trucks) 1793 - vehicle down the line (doesn't really have much meaning that we have been able to determine) Hope this helps! Tim |
12-27-2013, 12:07 PM | #9 |
Yes, Thank you mtflat, helps alot!!
