Old 07-03-2015, 11:49 AM   #1
ricklove
ricklove's Avatar
Default E-brake Problem/Question
1948 tudor sedan street rod w/GM 12 bolt rear-end and stock e-bake handle. Had it in the shop to make the e-brake work. They fabricated cable hook-ups, etc, etc, etc; but it still doesn't "hold" the car. When the handle is pulled, it has all of the "sensation" that all is working, but isn't. Shop says that there is always problems with new shoes & hubs, etc and it will work eventually as the shoes seat and "wear-down". Sounds like a crock to me, but I'm NOT a mechanic. Any input???
ricklove is offline   Reply With Quote
Old 07-03-2015, 11:59 AM   #2
19Fordy
19Fordy's Avatar
Default Re: E-brake Problem/Question
I bet the cable is too long. Hope they used as much of the OEM system as possible.
Here's how to adjust the stock 40 ford ebrake. Yours may be similiar.
Old 07-03-2015, 05:52 PM   #3
waterboychuck
waterboychuck's Avatar
I ordered this product from Speedway. http://www.speedwaymotors.com/Lokar-...ble,67521.html
I just received it yesterday and cannot get to installing it for some time, but I do agree that your new shoes have to adjust. At least that is what I found on my 48 F1
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 07-03-2015, 06:09 PM   #4
Dick
Dick's Avatar
I think it should hold if you can pull it tight enough. With it as tight as you can pull it is anything hitting a stop that keeps it from going tighter?
I installed the Lokar item waterboychuck gave the link to on my '49 F-1 and it preforms as expected, pretty easy to install also.
Good luck with this!
Dick is offline   Reply With Quote
Old 07-03-2015, 06:14 PM   #5
325w
E brakes work when they come straight out of the factory? No ( brake in ) needed? Ones I've had a problem with are usually not enough mechanical leverage.
325w is offline   Reply With Quote
Old 07-03-2015, 11:13 PM   #6
fordor41
fordor41's Avatar
I had sort of same problem on my '41. Installed a Ford 9" and ran e-brake cables to an approximate point to where the original met the cable to the handle. Would pull tight but wouldn't lock up the rears. Finally shortened the front cable and moved it forward beside the transmission and it worked OK. May have something to do with the angle of the cable that loops from the two rear drums
fordor41 is offline   Reply With Quote
Old 07-04-2015, 08:16 AM   #7
ricklove
ricklove's Avatar
Many thanks for the info!
Old 07-18-2015, 09:56 AM   #8
ricklove
ricklove's Avatar
Went for a 200 mile lunch drive yesterday in 98 degree temps. For some unknown reason, when I got home I felt my front rims. Seemed to be slightly above warm to the touch. The rear rims were hot!! Might the mechanics have adjusted the rear shoes too tight in an effort to make the e-brake work? Thanks!
Old 07-19-2015, 10:08 AM   #9
gmc1941
gmc1941's Avatar
Had the same problem. What I did was to take any excess out of the cable and housing. The cable isn't trying to straighten out the housing or other words the cable isn't fighting the housing.
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 07-19-2015, 10:55 AM   #10
dick lyons
dick lyons's Avatar
Press pedal firmly and at same time pull handle hard. It holds my 48 coupe hold on my driveway.
MNSHNR
dick lyons is offline   Reply With Quote
Old 07-19-2015, 11:07 AM   #11
flatheadmurre
flatheadmurre's Avatar
Its all about leverage and movement.
If your brakes are designed for a short throw and a high tension now bolted togetter with a longe throw low tension handle...handle seems firm but not giving enough power to the brakes.
Find out how much movement and tension the parts was designed for and if you got movement and need force build a lever under somewhere.
