05-04-2012, 01:33 PM | #1 |
1928 Model A wiring schematic
Any body out there have a full page of the wiring that is printable?
I found one from an earlier post but it so small that it is not readable. I tried to zoom in on it, but that didn't help either. Thanks, Harry |
05-04-2012, 01:46 PM | #2 |
Re: 1928 Model A wiring schematic
Here is the one I post often,
05-04-2012, 01:55 PM | #3 |
Mike,
That mite not be correct for his "28".....depending on what is on his car. |
05-04-2012, 02:22 PM | #4 |
Thanks Mike,
Now to get it shrunk to fit on one page.......my problem. Harry |
05-04-2012, 03:46 PM | #5 |
Is the red wire coming off the ignition switch go on the negative or the positive side of the coil
TKS |
05-04-2012, 05:01 PM | #6 |
Rusty Nelson |
05-04-2012, 06:05 PM | #7 |
Something is probably better than nothing...................
paul in CT |
05-04-2012, 06:20 PM | #8 |
There is a BIG difference....
Harry...inside your "light switch", is there 3 or 4 brass contacts, that turn with the horn/light rod? You need to know this 1st. |
05-04-2012, 08:30 PM | #9 |
mrroosk, if you wish to print the picture on one page just do the following. Hover your curser over the picture and do a right click on your mouse. A dialog box will appear. from this dialog box click "save picture as" and choose a location to save it to on your computer. then open the file on your computer and print the picture as a normal photo. You should be able to print picture in any standard photo size or A4. Trust this helps
Adjust your points with gentle blows of a 2 pound hammer |
