06-18-2016, 02:31 PM | #1 |
freeze plug replacement on 1924
Please! Any tips on the replacement of the center plug, has quite a bit of rust in outer ring , the plug itself is long gone and I have never had this come up befor and don't want to mess up which I seem to be very good at. Thanks in advance for any tips!! jim
iI |
06-18-2016, 09:28 PM | #2 |
Re: freeze plug replacement on 1924
Clean it up with a wire wheel or wire brush until it is shiny. Some guys use epoxy and then seat them in, others just seat in the plug.
'OSO HANDY RESTORATIONS Specializing in Model T Fords 320-293-1953 |
06-18-2016, 09:28 PM | #3 |
I seem to remember old engines with nickels used as plugs. I'm sure someone will have a good answer for you.
06-18-2016, 10:52 PM | #4 |
Thank you both very much, I am scared of todays nickels, I have no idea what the govt. is making them out of now so guess I will go with wire brush and plug, thanks again for your time and knowledge Ford barns people are the best!! jim
06-19-2016, 09:50 AM | #5 |
You can get Buffalo nickels with the date worn off for 25 cents at most coin shops. Cheaper than a steel freeze plug and better too.
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
06-19-2016, 04:36 PM | #6 |
06-19-2016, 09:53 PM | #7 |
I use the brass plugs with a little permatex. Make sure the lip is good and clean. You might as well replace the other 2 while you are at it. Put it in dome out, then tap the center to spread and seal in the hole.
