Old 02-29-2024, 01:18 PM   #1
jeepguy1948
Default A Flywheel on a B
Will A Model A flywheel work on a B motor?
jeepguy1948 is offline   Reply With Quote
Old 02-29-2024, 02:21 PM   #2
J Franklin
J Franklin's Avatar
Default Re: A Flywheel on a B
yes
Old 02-29-2024, 03:15 PM   #3
Charlie Stephens
Yes, UNLESS (if I remember correctly) you are running a Model B transmission in which case it will interfere with the bell housing unless you have it cut down slightly.
Charlie Stephens
Old 02-29-2024, 10:49 PM   #4
jeepguy1948
Nope, not a B transmission Thanks for the assist!
Old 03-02-2024, 11:57 AM   #5
Jim Brierley
A flywheels are heavier than B's.
Old 03-02-2024, 10:02 PM   #6
jeepguy1948
I have a lightened A flywheel but now that I am swapping in the B motor I wanted to be sure I could use the one I already have. Looks like I can!
Old 03-03-2024, 04:46 PM   #7
ModelA29
ModelA29's Avatar
I think you'll need to trim the back of the B oil pan to use the A bell housing and trans.
ModelA29 is offline   Reply With Quote
Old 03-03-2024, 07:26 PM   #8
jeepguy1948
That’s what I understand although I have not seen how it all goes together yet.
