Old 12-11-2010, 10:25 PM   #1
masonj
Question Squeeky Springs
The springs squeek while driving my 1950 F-1...has anyone found a good remedy for this?
masonj is offline   Reply With Quote
Old 12-11-2010, 10:44 PM   #2
PeteVS
PeteVS's Avatar
Default Re: Squeeky Springs
I remember being at a gas station with my uncle once when he was getting a lube job on his '51 Chebby. The grease monkey used a hammer and cold chisel to open up a gap between the rear spring leaves and shot some chassis grease in the opening. You could also disassemble the springs, clean them up and install the plastic liner material they sell at Speedway, etc.
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 12-12-2010, 01:03 AM   #3
Old Henry
Old Henry's Avatar
Here is an idea that has been known to work:
Lift up the vehicle at the frame until the wheels are off the ground to "unspring" the springs as much as possible.
Using good heavy bearing grease, smear a heavy layer of grease on all surfaces of the springs from U-bolts to shackles, particularly on the tops/bottoms of the leaves at the end of the leaf above/below it.
Using duct tape, wrap the spring from the U-bolts to the shackles making a sleeve that will temporarily contain the grease and allow it to work its way between the leaves of the spring without attracting dirt and other road grime.
Drive the car for a couple weeks worth of good driving prior to removing the tape and thoroughly cleaning the spring(s) of excess grease. If you do not drive your car much, it may take longer to work the grease between the leaves of the spring(s).
This was demonstrated on the Do-It-Yourself Network
Old 12-12-2010, 01:41 AM   #4
Old Henry
Old Henry's Avatar
That's probably the only real permanent fix. That's what I did on my front springs. My back springs on my 47 Super Deluxe have spring covers and 3 grease fittings to keep them lubricated.
Here are liners of various sizes at Mac's: http://macsautoparts.com/search.asp?...liner&x=16&y=6
Old 12-12-2010, 03:10 AM   #5
tudorbilll
Arrow Re: Squeeky Springs
I had to dissasemble the rear of my 35 to stop the Squeeky spring use heavy grease.I was suprised how much whear there was.
tudorbilll is offline   Reply With Quote
Old 12-12-2010, 07:42 AM   #6
PeteVS
PeteVS's Avatar
Also, someone posted recently that painting spring leaves and not lubricating them makes the spring rate much higher (stiffer) because of increased friction between the leaves. I've been looking and posting for some time trying to find John Deere "Slip Plate" dry lubricant. I don't think anyone has stepped forward for a source. (I live in suburban New Jersey where the only John Deere presence is lawn mowers.)
Old 12-12-2010, 11:45 AM   #7
Wltr_Mitty
Wltr_Mitty's Avatar
You can buy Slip Plate at your local NAPA store. Stock #BK 33203. I use it when rebuilding spring packs and it works great. It goes on like an aerosol paint.
Clean the leafs individually and paint them with a good rust preventative paint. I first give them a coat of rust converter for good measure. Give the paint time to dry, then coat all of the bottom surfaces (except the main spring) with the Slip Plate and let it dry before reassembling.
Wltr_Mitty is offline   Reply With Quote
Old 12-12-2010, 11:54 AM   #8
Steve Staysko
Steve Staysko's Avatar
Order it direct from www.slipplate.com Slip plate is great stuff you can use it between your leaf springs of your antique cars and then you'll say now what do I do with the rest of the 3/4's of a quart. Well I've used it on the fifth wheel no more messy grease. I've painted it on my tractors snow plow blade and the snow doesn't stick to the blade. I even paint it in the shut and the auger area of my snow-blower and it stops the heavy wet snow from sticking to the metal discharge chute and throwing stage. Every spring I clean the bottom of my mower deck and paint it with slip plate and it keeps the mower deck free of clinging wet grass.
Steve Staysko is offline   Reply With Quote
Old 12-13-2010, 12:26 PM   #9
Karl Wolf
Karl Wolf's Avatar
Motorcycle chain lube... spray can... Karl
Karl Wolf is offline   Reply With Quote
Old 12-13-2010, 02:23 PM   #10
Mr 42
Mr 42's Avatar
Remove the springs disasemble them remove all rust, and smoth out the ends Grease them and drive on for 50 more years.
Clean off the wear marks, assemble them with some grease and they work like new. This is a dirty job, but well worth the effort.
This is the underside of the spring, round of the ends a bit so it will slide better.
Mr 42 is offline   Reply With Quote
Old 12-13-2010, 02:53 PM   #11
jerry grayson
Mr42 has the answer. All the other lube and spray fixes are only a band aid. In 1936 Ford changed the design on springs to include a grease fitting and groves in each leaf. In your case the later pickups did not have a grease system. The springs did not squeek when new, so you need to return them to as new as possible. This means that the springs will have to be disassembled and the wear grooves ground down. Each leaf will wear a cross ways groove in the next bottom leaf over time. This is what is making the noise. See Mr42's pictures.
jerry grayson is offline   Reply With Quote
Old 12-13-2010, 10:05 PM   #12
masonj
Thanks for the input...looks like I need to bite the bullet and take them apart and do it right.
Jack
Old 12-14-2010, 06:18 AM   #13
PeteVS
PeteVS's Avatar
Thanks for the sources for Slip Plate!!
Old 12-14-2010, 05:29 PM   #14
bardahl1
This
bardahl1 is offline   Reply With Quote
Old 12-14-2010, 05:58 PM   #15
Ken Crans
Ken Crans's Avatar
If you are taking them apart, don't forget to deburr and radius the ends also. Go with the liners if possible. Ken
Ken Crans is offline   Reply With Quote
Old 03-23-2011, 01:01 PM   #16
Clem Clement
Clem Clement's Avatar
I have removed the spring clamps, opened the leaves with 2 chiesels, washed between the leaves with carb cleaner and sprayed the leaves with Slip Plate.
I've wrapped the springs with duct tape. I'm wondering if that is a dumb move as it may trap water inside?
clem
Clem Clement is offline   Reply With Quote
Old 03-23-2011, 05:08 PM   #17
John R
Clem, Back in the day, we used electrical tape to wrap springs. Worked great. Good quality (3M) electrical tape has some "give" to it which helps in getting a good wrap and maintaining it as the spring flexes.
John R is online now   Reply With Quote
Old 03-23-2011, 07:04 PM   #18
Clem Clement
Now I'm thinking about trying to grind the depressionon the worn spring with a dremel. Then sliding a piece of tin can under the spring end. Whatayou thunk?
Clem
Old 03-23-2011, 07:31 PM   #19
richard crow
back in the day we would mix old motor oil with gasolene 50/50 with the wheels hanging we sprayed between the leaves. it was also comman in this part of the country in the fall to spray the whole bottom of the car with oil to prevent rust. there was very little rubber bushings in those days you would get locked up today if you did it. it was also common pratice to spray the roads with oil to keep the dust down in the summer.
richard crow is offline   Reply With Quote
Old 03-24-2011, 08:28 AM   #20
Clem Clement
For years I used to soak the underneath of my moderns. nothing rusts. My son had a pickup in Michigan for 5 years with no sign of rust. I would wipe the brake hoses wilthgas to remove the oil. I used only used oil for this job.
Clem
