11-01-2018, 04:02 PM | #1 |
brakes
A while ago I asked about improving brakes on my 40. I installed the Bendix kit from Boling Brothers, and just finished rebuilding the Lockheeds on the rear. I had soft linings bonded on at the frictions place in Portland, and rebuilt the wheel cylinders. Just waiting for help to bleed and hopefully will see a big improvement.
11-01-2018, 04:46 PM | #2 |
Re: brakes
Looks nice.
11-01-2018, 07:25 PM | #3 |
Re: brakes
What was the name (and number/email) of the company that did the relining?
Thanks
11-01-2018, 08:22 PM | #4 |
Re: brakes
All Frictions, Portland, Connecticut. He even had me measure my newly machined drums and contoured the shoes to match. $20 per shoe. He did the brakes for both model A Fords also.
http://allfrictions.com |
11-01-2018, 09:52 PM | #5 |
Re: brakes
Any thoughts on the use of the same lining length on both shoes vs shorter lining as used originally on the rear shoes?
11-01-2018, 10:20 PM | #6 |
Re: brakes
11-02-2018, 07:29 AM | #7 |
Re: brakes
I have read that it is not important. Perhaps the short shoe was to save money.
11-02-2018, 09:24 AM | #8 |
Re: brakes
Another recommendation for "Speed-Bleeders". They will make your life a lot easier.
11-02-2018, 09:47 AM | #9 |
Re: brakes
Did the same on my 40 wagon. Took a whole 15 minutes to bleed all 4 with a helper (wife). No gimmicks just a wrench, rag and some brake fluid. It's not rocket science!
11-02-2018, 09:52 AM | #10 |
Re: brakes
Speed Bleeders make it easy. Buy the longer ones to make it even easier.
Part #SB3824L for 40 Ford but, double check size you need. Yes, they actually make this a one person job. See how it's done. https://www.youtube.com/watch?v=3VMV51FUA7A Last edited by 19Fordy; 11-02-2018 at 10:12 AM. |
11-02-2018, 10:04 AM | #11 |
Re: brakes
we just finished a 40 sedan with the Boling Brothers front brakes--very impressive, will slide front radial tires . No wonder all the old hot rodders looked for 39-41 Lincoln brakes
11-02-2018, 11:26 AM | #12 | |
Re: brakes
11-02-2018, 11:47 AM | #13 |
Re: brakes
I don't know about you, but I find it difficult at times to get a helper to drop everything and come out to my shop. Speed-Bleeders make it a true one person job. Try doing it all by yourself without them. I wouldn't call them "gimmicks" either.
11-02-2018, 09:52 PM | #14 |
Re: brakes
Speed-Bleeders work great. And you don't have to listen to the wife or daughters bitch about having to help bleed the brakes...
11-02-2018, 11:40 PM | #15 |
Re: brakes
I have a buddy that we always share the chore with. There have been times when I have to bleed them alone. I cut a stick that goes from the front of the seat to the depressed brake pedal. With bleeder open I press the pedal down and install the stick. Then I go back under and shut the valve. Repeat, repeat, repeat....It's pretty horrible but it does work fine. When my buddy and I work together it takes exactly two beers each to perform the task. Pretty much a win/win. I DO think the valves sound like a great idea, but it's nice sometimes not to be working alone.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-03-2018, 08:29 AM | #16 | |
Re: brakes
11-03-2018, 11:23 AM | #17 |
Re: brakes
I can help next week in the afternoon, not Mon or Tues.
Paul |
11-03-2018, 02:04 PM | #18 |
Re: brakes
i do it like GB, by myself with a stick jammed into the seat, or a bungy strap to the frame when doing a bare chassis. easier than looking for help
11-03-2018, 02:12 PM | #19 |
Re: brakes
On my 41 pickup I used a vacuum bleeder kit. It took me a while, but I was able to bleed it successfully on my own.
Mart. |
11-03-2018, 10:51 PM | #20 | |
Re: brakes
Thank You
