Re: What came original?
An Early 28 has the emergency lever on the left next to the drivers door...no question !
Also has a red steering wheel.I'm from Canada and currently restoring an AR tudor. Founding out lot's of @##%$. The number on the engine and the frame starts with CA if its Canadian and they should be the same or close.They also use robertson (Square) screws in most cases. Also has the multi disk transmission and no separate emergency brake linings. Over the yrs though someone could've swapped these out. The interior should also have (at least mine does) a 2"coachlace trim around the beltline(below the windows). I've found a weaver in Penn that will reproduce these...NOT Lebaron Bonney or Cartouche for some reason.
