Old 10-10-2011, 02:01 PM   #1
Roger/Sacramento
Roger/Sacramento's Avatar
Default Chrome the crank journals ?
Years ago guys would brag that they had chromed crank journals. Why not now ?
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 10-10-2011, 04:07 PM   #2
41ford1
41ford1's Avatar
Default Re: Chrome the crank journals ?
Roger,
You may want to read this if you are thinking about chroming a crank.
http://forums.pelicanparts.com/911-e...k-std-std.html
Chuck
41ford1 is offline   Reply With Quote
Old 10-10-2011, 06:58 PM   #3
rotorwrench
rotorwrench's Avatar
I've had several shafts repaired with hard chrome but they were power transmission type shafts that had a small journal that needed built back to specs to keep the tapered roller races a tight fit. A crankshaft is a whole nother ball game. I've heard all sorts of stories about welding up journals to get long strokes and hard chroming others but it is a gamble. The shafts I had repaired were $6500 new and the repairs ran about $1500 so it was worth it on those. On the old Pratt & Whitney radial engines they used to hard chrome the link rod bushings back to specs but they wouldn't touch the master journals.
Kerby
Old 10-11-2011, 03:37 AM   #4
JWL
The theory of applying a very hard, slick, surface to the crank journals is a good one. And, the chroming process offers the added advantage of being able to increase journal diameter so a mildly worn journal can be restored to original size. However, the strength of a steel crank is sacraficed when dunked in the chroming tank for several hours. I, personally, have never chromed a stock Flathead nodular crank and have not explored the possibility. But I have had some Boss 302 forged steel cranks done and know that one of them broke.
JWL is offline   Reply With Quote
