Old 12-14-2012, 12:54 PM   #1
BW
Default 1936 Ford door latches
Hi, Can anyone tell me if there is a difference in the door latch of a Cabriolet and a Coupe besides the arm. Thanks BW.
BW is offline   Reply With Quote
Old 12-14-2012, 09:50 PM   #2
TJ
TJ's Avatar
Default Re: 1936 Ford door latches
The cabriolet definitely has a different door latch than the coupe. Door latches for the coupe, tudor and fordor are the same.
Old 12-14-2012, 11:22 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
I don't have a cabrolet, I have a conv sedan, in looking for NOS latches I looked at a lot of doors to see what is the same, the pic of 3 latches are closed car latches, the 2 in the other pic are for conv sedan35-40, and I know 37 on cabrolet for all,--35 cabrolet has latches like closed cars ---I have seen both kinds in cars claimed to be 36
The 28-39 trim and hardware book has pictures and listings with measurements of the linkage rod
Do you have pictures of the striker, or the hole in the door? ---
Old 12-15-2012, 09:22 AM   #4
BW
My striker is the same as a coupe and my old latches look the same as your pictures. I was told the only difference was the arm length. I found a set of new ones Part # 48-702411-C LEFT AND A 48-702410 RIGHT I'm hoping they are right but I don't know.
Old 12-15-2012, 10:24 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
The latches in my picture of the 3 latches are NORS--aftermarket, they came without the linkage rod so they would fit all the cars with that type --and some
Mopar cars of the same era. ---I bought them to use as parts to rebuild my worn drivers door latch, then I found the NOS ones that are in the other picture.
The closed car type are often on E-bay for reasonable prices, many times NOS at the same price as used
